Hey guys, im newish around here, just got my new skyline (silver v35 :) ) and now its time for me to run a scruise since no one else in perth seems willing as of late. Still finalizing map, PM me if you wanna have a look at it or give me any suggestions. Details as follows:
Place: City West Car Park
Date: Saturday 29th December 2007
Meet: 8.30pm
Depart: 9.00pm SHARP
As it is atm the map has a nice run on the fwy, tunnel run, a bit of a run in the hills, and most of it is dual carrigway roads. Its about 220kms so make sure you fill up befor you come or there are some petrol stations at or very close to most of the meet points. Its brocken up into 4 legs of 50 and 60kms and goes pretty much all over perth. But like i said Pm me if you wanna see a look at the map befor sat or if you wanna offer your suggestions. Hope to see some of yas on the cruise and that everyone will have a good time.
https://www.sau.com.au/forums/topic/199289-open-cruise/
Interesting, have you driven the hills section you have mapped out? a lot of the roads are pretty sh!t, cruise last friday night had ~50 cars coming down a single lane road with an indeterminable dropoff (it was pitch black) with sharp hairpins requiring people to do 3-4 point turns :D
https://www.sau.com.au/forums/topic/199289-open-cruise/#findComment-3553473
hey me and a mate are interested we both have skyline one a 32 and one a 33 but mine is off the road with a yellow so i will be with me mate in his 32 "SLYDR"
is there many people going , is it just a import cruise or all ?
if there is anyone who want to meet up before hand text sam on 0433238206
cheers
https://www.sau.com.au/forums/topic/199289-open-cruise/#findComment-3555205
cheers
open cruise
https://www.sau.com.au/forums/topic/199289-open-cruise/#findComment-3555603
Good cruise guys, Nice to meet some new people.
Luv that R34 GTR M spec Nur edition.... Awesome car.
Good map, not too much trouble.
We had fun & no Cops. Sorry I had to bail early, (1:30 am). Damn! missed the tunnel again!!
good to see that most people were well behaved!
looking fwd to the next one.
https://www.sau.com.au/forums/topic/199289-open-cruise/#findComment-3556792
most ppl well behaved... not me, sorry... i was naughty... couldnt really help myself, had like a crowd yelling burnout burnout and so on.... but on the bright side, i didnt have sauwa stickers up... so sorry is in order i guess... but i enjoyed it!! so :D
https://www.sau.com.au/forums/topic/199289-open-cruise/#findComment-3557127
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity.
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
