ive done a search for this on the forums already and not much info, the kit looks hot as! ive also seen a series 2 gtst r33 with this kit on it sexy as! anyone have any ideas how much this would cost fitted and painted? or even how much it is to buy and where? or if the guy with the kit on his 33 could enlighten me with info it would be great :D
https://www.sau.com.au/forums/topic/199618-r33-kakimoto-bodykit/
couldn't tell you for sure who could do it for you, the J-Spec one is an original kakimoto fitted in japan by kakimoto.
Ernie from Skyline Imports up in QLD had a modified copy of the kit (they relocated the rear wheel arch) and they fitted it up to a few cars running around in QLD... but last I heard kakimoto contacted them and threatened legal action if they didn't stop installing them. Although that could just be rumour.
http://www.kakimotoracing.co.jp/05-00_earo..._earo-kr33.html
2700, not a bad price at all, now when you say all up does that include fitting :blink:? lol i imagine fitting + painting another 2700 so 5400 for a widebody r33 not too bad then add money for wide rims another 4000 hahaha and were getting into personal loan territory, best email dmd soon :) thanks all this kit is so drool worthy cmon tax return 2008!!
HAPPY NEW YEAR EVERYONE ! :D
just make sure that when you have the kit fitted that you actually adjust the castor of the wheels to suit. the kit was designed by kakimoto to slightly elongate the wheelbase in addition to giving it extra track (as this kit was meant for use on race cars, not just for looks). when Skyline Imports modded the kit they retained the factory castor of the wheels, and relocated the wheel arch so that the wheels wouldn't scrub against the kit.
So depending on whose moulds DMD uses to make their copies you may or may not have to adjust the castor.
some pics:
http://www.skylinesaustralia.com/forums/in...t&p=3398639
Also I don't think whoever did the moulds did the carbon wing and the carbon splitter under the front bar. I've never seen a fake with those bits, and as much as it looks huge and out of place, you have to sit inside the car to appreciate the wing, as it specially shaped to disappear into the blind spots of the car so it doesn't impede the driver's vision. Plus if you're gonna go balls out with such an intricate wide kit, you want to make sure you have the entire "signature look" package.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
