i've tried searching this on google but it's not helping me much. ne1 know where i can actually see the different colours of 34 GTRs that you can buy? i know we got the paint codes but that just tells me the name when i would like to see the colour. ne help would be much appreciated.
Edited by rubzy
https://www.sau.com.au/forums/topic/199664-34-gtr-colours/
  • Replies 43
Im also interested in this, particularly the difference between the silvers (athletic, sonic, ztune etc etc)
https://www.sau.com.au/forums/topic/199664-34-gtr-colours/#findComment-3557609
There are rare millenium jade ones..that are like the 180sx champange colour
So HAWT!!
A bit weird google cant show it up??
Tried googling Nissan?
Used to be able to bring up all the makes and colours..see what I can find for you :(
https://www.sau.com.au/forums/topic/199664-34-gtr-colours/#findComment-3557657
F**k me cant find anything that will link to pics of the actual paint code..
I do have a disc at home that might have some thing on it..
Is there any colour in partuicular you dont know what it looks like?
Found a different way of doing it...
http://www.skylinesaustralia.com/forums/Ni...es-t138419.html
There are your R34 paint codes ..go google click on images up the top and google the full paint code and name should bring up pics of the car and what it looks like.. I tried it for milenuim jade and midnight purple 3 colour and it did bring up pics of the cars with that paint
Its a bit time consuming but the only way I can find that works!!
I cant actually find a list of the R34's with there different paints :(
https://www.sau.com.au/forums/topic/199664-34-gtr-colours/#findComment-3557707
sorry for hijacking the thread but anyone know where to get standard nissan paints in adelaide? need some gun metal grey...
dont they sell em to you from the nissan dealerships? probably expensive but have you asked them yet?
https://www.sau.com.au/forums/topic/199664-34-gtr-colours/#findComment-3557834
we should talk cause i need gun metal grey also
im thinking protek paints could mix it
https://www.sau.com.au/forums/topic/199664-34-gtr-colours/#findComment-3557848
the pic of the car above is called 'nurside' - yet is looks much more like a Z Tune to me! (Without the stickers of course). However check out the horrible colour match on the rear bumper! (May be the light I suppose).
https://www.sau.com.au/forums/topic/199664-34-gtr-colours/#findComment-3558228
So HAWT!!
like this colour?
http://www.j-spec.com.au/list/index.php?ID=11895
https://www.sau.com.au/forums/topic/199664-34-gtr-colours/#findComment-3558613
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
