Item: 04 Honda Crf250R RAMS modified
Condition:Very Good
Price: $5,500 ono
Contact: 0414354342 or 0265554342
Comments: I can add pics or email pics.
Call Ian 0414354342 or 0265554342
04 Honda crf250r
4 rides since Full re build by RAMS! starts 1st kick every time!
Shell 98 octane V power fuel used always
Washed and cleaned after every ride!
Bush ridden and a few back yard track rides.
Selling because i haven’t ridden 4 over 12 months. It’s just sitting in the garage. I start it every couple of weeks 4 a few minutes.
06 head ported and polished by Rams.
Eceldyne titanium valves, springs and seats.
13.5 compression JE racing piston and rings.
CHM titanium exhaust (Full) Top of range US exhaust!
Carby rejeted with spear jets
Heavy duty tubes (front n rear)
Gold TAG handle bars
Renthal chain n sprockets
99% front tire
70% rear tire
New fork seals n fork seal protectors
Light speed frame protectors
Brand new twin Air air filter
Factory fx sticker kit
B & B bash plate
4x spear leavers, 2x spear air filters.
Full spears kit, gaskets, piston n rings.
Work shop manual
Owners manual
All standard parts
All recites for head, head work, piston, exhaust, jets, Fork seals n protectors, bash plate, everything!
post-5828-1199315962_thumb.jpgpost-5828-1199316036_thumb.jpgpost-5828-1199316138_thumb.jpgpost-5828-1199316197_thumb.jpg[
Edited by Bullant47
  • 1 month later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
