hey mate,
what led's did u use for dash lights... i brought sum of the proper blue t10's (think thats what they are called) from 666DAN on here but only worked for a week or so and now none of my dash gauges light up (only warning lights and indicators do so).....
thinking it may be faulty dash clucter tho
bought them on ebay @ 20 bucks, they are the ones with about 5 little LEDs on the t10. 2 of them just stuffed up the other day and im looking into making some new ones myself which can handle the voltage, i'll let u know how I go.
Nice dash lights but not a big fan on the glitter interior. Just a suggestion, if you have the spare cash perhaps a new steering wheel. Im looking into getting one probably momo but not sure which model as yet, any suggestions ppl?
In re to 666Dan leds, originally he was supplying Leds that handle only 12volts of current but after a few complaints from ppl stating their lights would randomly flash & then eventually die in the ass he investigated the matter and discovered the dash voltage level in the skylines would randomly fluctuate. He now supplies 16volts leds which i have recently installed & so far so good but it's only been a week, so finger's crossed. Blue leds rock!
Nice work mate! Unique. I have the blue 5LED globes and none of mine work atm....they come on randomly but I havent had a full cluster in ages! Cobalt gauge selection tops it off. I wouldnt go changing steering wheel, I like the stock one, besides, jus as an example, here in Mildura I hear of people being done for not having an impact material on their wheels and replacing the airbag is a big no-no. Ur call tho. Do I see AVS rims under your car??
Once again, great to see individual tastes and ideas, even if they arnt everyones cup of tea!
Yeah, thanx mate. U can't c in the photos but at night under the proper light u can see my purple pearl through the clear which i put on top of the glitter spray ( the photos were done via my phone so they don't look right). Anyway I got the autometer cobalt series because they were the only gauge that matched the stock cluster and i wanted the needle in the gauge to be lit, but little did i know that they lit up blue at night, so i had to change my cluster lights cuz i hate it when they don't blend in. PS. those are AVS shoes u c, but will be white 19" Enkei soon i hope..
Well, it's RICE... however, I have to say, you tastefully 'riced' up your car. LEDS are nice and make the car look clean and sporty in my opinion whereas the consoles and glitter etc are your opinion so don't let anyone tell you what you should or should not do - -personal taste.
Overall, nice... I'll PM you as I need new dash LEDS and might need your help - I'm from Melbourne too.
Looks good Steve,
How did you take the drivers door control panel off? I've resprayed my dash a matt black, and now need to do the door handle bit.
 Hi, thanx. U need to look in the coin hole and u'l see a little black cap at the bottom, take the cap off with a small flathead screwdriver (from the right hand side) and u'l see a screw under that. Unscrew that and then you can yank it off, don't be afraid to use a little force because its clipped in aswell. Same goes for the passenger side.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
