Hey all,
I just got a phone call from a mate saying that there are cops galore on the Hume between Campbelltown and Picton turnoffs, they're pulling any form of modified car over and obviously giving them a good shake down.
There are also unmarked cops patrolling, and a cops parked in any U turn or stopping bay...
if you're headed to Canberra, make sure your car is 100% legal, find another way, or dont bother going... either that or bend over.
Remember its Double demerits and fines until the 6th... so it could be very painful.
cheers,
Bj.
https://www.sau.com.au/forums/topic/200022-summernats-warning-hume-hwy/
  • Replies 51
after driving to and from melbourne just before NYE i encountered a massive amount of cops, sitting in little towns, anywhere with a speed difference, and on the general highway sitting in the darkness too......
slow down and stay safe people its not worth speeding to get there a small amount of time quicker!
Actually there is defects which carry points.. seatbelts, seats,steering, and wheels I think include some.
Loud sound system also carries points.
Its on rta website, type in offences i think comes up with a list or demerit points actually
Edited by DECIM8
Can they do that? If they can... Should ask for a location which was private property to unload on as it wasn't intended for the road.
We take track cars on the back of the track and they are in no way street legal, I'm really surprised if they can ask you to unload them.
Yes, they did that by making the owners drive the cars off the trailers and then defecting them. Bastards.
basically wouldn't that consitute as them asking you to do something completely illegal?
If the car on the trailer is registered then they can defect it because you have the intent on driving it on the road (otherwise it wouldn't be registered would it).
In the last 3-4yrs i've been going to the Nats it was only the first time that i was pulled over and that was at an RBT station where they did a db reading on my exhaust which I obviously passed. After that I drove my van for the last 2-3yrs and havent had an issue or seen any issues.
The only thing they could get me for on my current gtr is pod filters, hrmm need to find a standard box.
however, those mods may have been intended for track use only, they cannot prove that it was intended to be used on the road without seeing it on the road, registered or not.
I stand corrected. Seatbelts, brake and steering carry points (3 each) and undue noise under the Protection of the Environment Act carries points as well.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
