ever heard of sarcasim sled?
thats why i suggested earlier that somone else with an idea of the local area would be better suited to organise a cruise.
also someone that knows how to drive on something other then the Adelaide O-Bahn.
I know.........I'm only pulling your leg too mate
  • Replies 78
Posted Images
cara i won't be able to make it now, really busy sorting out work ect
aww thats a shame :( but good luck with it all though hope u find something soon!!!!!!!!!!
so who have we got coming on the cruise on saturday?
yeah know exactly where your coming from i just got permanancy after 2 years @ the same place after being with the agency for 4-5 years my old man has been with an agency for around 10+ years :)
you are now a 'permanent agent' Steve
it sucks being agency but im trying to find a fulltime job mon to fri atm lol need human hours! and the whole fact that i wont need to be umming and arring over whether im gonna have any work and monies.........kinda over it atm
What happened to this cruise ? Did it go ahead ?
It was sunday , then saturday , which one is or should I say was it?
logged on this morning to get fine details and cant work it out . LOL
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
