Has anyone tried Musashi Bulk? Ive tried looking for reviews but can't seem to find any.
I'm considering buying some...
Yeah I have used it quite a bit in the past. I consider it a pretty "safe" protein powder, as in it won't really mess with my gut (no creatine), and it's made by a proven, mainstream manufacturer. I used to use it in conjunction with Musashi 92, depending on the time of day or if it coincided with my workout. The Bulk has carbs, so it's better for pre or immediately post workout, while the 92 has very few carbs so it's better as a supp before bed, in the morning if you know you're having carbs for breakfast, or just as an in-between-meals protein shot.
You can definitely get both of those cheaper online rather than through the shops.
LOL
No, but if it's a daily and you need to keep driving it you don't drive it at 100% WOT until you've fixed the miss...
I get your point, all I was saying is that I'll avoid those movements right now until I've had a chance to get into physio, have it assessed and continue with recovery steps, in the mean time I can at least get a little leg work in with some lunges without straining that nerve/muscle/whatever it is.
I've got a holiday starting this Friday so can give it some rest then, be lucky if I see the gym at the hotel twice while I'm away.
You didn't have to edit out Laser GLI and change for Meteor either, I got it the first time :D
Edited by ActionDan
Squat - The exercise = deep squat.
Squat - The event = hip crease below knee height.
If you are not a competing lifter lifting a massive weight for 1 single rep - squat all the way down
Do a test.
load up your bar with whatever you squat for 10 reps and do 3 sets of 10 reps to parallel.
next session to the same weight and sets x reps but squat deep.
It will be harder and you will feel soreness you didn't with the parallel squats.
Foot position is not so important.
what ever makes your knees feel OK.
generally, they will point outwards.. probably closer to 30 degreese that 45.
Both deep and not-so deep (parallel or just below) squats can work.
There is debate over which is safer but, basically either done right will give an equivalent development.
Well respected athletes and coaches on both sides of the methods. Arguments are mostly on which is less injury risk.
I've done and had training on both. I believe either can be done safely enough but, like an advanced driving course squats are much better experienced with a few expert lessons. Whatever the instructor shows you , do that. It all works, just not so well if you have been coached (term used loosely)by people with bad habits themselves.
You could start a whole thread on discussing them that's for sure.
Rack http://www.samsfitness.com.au/products/bench-presses--power-racks/powertec-power-rack
Bench http://www.samsfitness.com.au/products/benches/powertec-utility-bench
I'm not going to get around to setting it up until next week I reckon because I've just moved into my new home so I have a lot of other things to do (reason I haven't lifted/eat properly in over 2 months), lost 4kg....
I have weights and bar but I don't have a weight stack yet but will get one when I get around to it. I'm going to have the rack sitting on carpet, you reckon it's worth getting the matts for underneath?
Depends if you care about your carpets.
Rubber mats might also leave a stain on your carpets.
Dans idea of a carpet mat on top of the carpet might be a good idea.
If you give no fark for your carpets then don't bother.
Mine is outside on a stencilled concrete patio floor so I have rubbr mats even though my plates are rubber coated.
it protects both the floor and plates.
    • I had a 1981 ALFA with an electronic speedo sender that would work for months at a time, and also noth work for months at a time.
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
