Cheers TTT.
I think I get wha muscles she's targeting now and she said that was the aim between now and the next session, learn to think about/activate them and do some light exercises.
The exercise she gave was to lie on my back, feet flat and legs bent, activate that muscle then lift my arse off the ground while holding tension in only that muscle and not using my "outer" abs.
Also, she mentioned I should avoid crossing anything, as I tend to sit with one ankle rest on the other leg above the knee etc, now that I'm thinking about not crossing things I'm realising how often I do it, sitting, standing always crossing in some way, even sleeping.
Edited by ActionDan
HE DID MISTYPE IT HE DID HE DID HE DID!!!!! hahaha
Also it's not just MY quoting - SAU in general is all f**ked up right now. There's no 'multiquote' option, no text formatting options, no emotes, and whenever you quote someone it adds that stupid HTML bullshit to it and doesn't show who you're quoting.
HE DID MISTYPE IT HE DID HE DID HE DID!!!!! hahaha Also it's not just MY quoting - SAU in general is all f**ked up right now. There's no 'multiquote' option, no text formatting options, no emotes, and whenever you quote someone it adds that stupid HTML bullshit to it and doesn't show who you're quoting.
Seems to work fine for me.
I've just tested and I cannot multi quote, it just grabs the first one and proceeds to posting window.
Using Chrome.
that's a shame
What browser? Cleared cache/deleted cookies? Rebooted? Tried a diff browser?
I occasionally get the odd issue with the forums but they mostly resolve themselves.
I'm pretty sure TTT will tell you to squat the problem away.
I'll keep that in mind if we're hiring and you apply lol
hahahaha snap! :P I do my work, it's just when it comes to fixing my own issues sometimes I just don't see the point when I can make do how it is lol. Plus I get the feeling I won't be leaving my position any time in the near future....considering my role and workload, I'm disgustingly overpaid where I am ;)
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
