hey guys
i need new tyres for my R34 GTR rims... atm its 245x18x40 (9")
i want to get 255's (protects my rims for gutter rash and for a wider look)
but not many brands do 255x18x40
can u guys recommend any?
i want to get more of a mid-end tyres/brands ...dont really want to spend too much on high-ends like s-03 etc
as i have AWD
cheers,
Andy
https://www.sau.com.au/forums/topic/200866-new-tyres-for-stock-r34-gtr-rims/
to maintain rolling diameter, shouldn't i be using the same 40 profile? (stock)
why change to 35's?
40 and 35 are a % of your tyre width, not a set measurement...as your tyre width increases, to maintain overall diameter, the % decreases..
Use this calculator to determine:
http://www.1010tires.com/TireSizeCalculator.asp
Actually...265/35 would be a closer match to your 245/40. Least difference in diameter..
Edited by n15m0
Factory they're 245/40 ZR18 Potenza RE040
I'm currently running Toyo Proxes F1 same profile as above.. but I can't begin to tell you how much better they are than the Potenzas. Gutter rash, yes i've had a little bit of that... *fking drive through and my carelessness*... you might want to look at running just 255's on the rears and not the front though.
thanks for that, calculator is useful :P
gutter rash is pain, esp when u want to squeeze in somewhere
for AWD, i need to run same size for all 4's
Most 34 GTR's you will find run 265/35/18, a 275/35/18 would be a better match, but these tyres are not as common as the 265's.
We have all the sizes mentioned above, brands like toyo, dunlop, yoko..., however i recommend the 275, especially seeing you want a bit of cover for your wheels.
I've sent you a pm on the prices,brands and sizes in 265 and 275 which im sure you will find impossible to beat.
GTR's have to run same all the way around.
265's are too baggy on a 9" wide rim I don't recommend it, you get too much sidewall movement. Don't even bother with 275. Rwd gain a bit of off the line traction with baggyness, but being a GTR you have 4wd so you don't need that, what you would prefer is less movement from the tyre for more responsive handling.
Stick to original 245 or you can go up to 255 if you want. I've run 245,255 and 265 on my 34GTR rims.... so this is from experience.
As for gutter rash, just be extra careful around gutters :(
For a reasonably priced ok performing tyre, have a look at the hankook k104's - they come in 255... probably around 1000-1200 for a set.
I got brand new 2 tyres RE001 Bridgestone adrenalin that i got 2 weeks but sold my rims before i got the delivery so yuo can have them if they fit your rims. They are ultra hi performance 245/45/18. any reasonable offers considered. i bought them for $690 from Bridgestone tyres.
got them on my car atm
um i need 4 unfortunately :P and at least 255's
ppl will snap them up quickly if u put them in the 'for sale' section
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
