  • Replies 43
do it right the first time:
alloy fuel tank
carter lift pump
aeromotive a1000 pump
aeromotive a13110 fuel reg
aeromotive filters
2ltr surge tank
jap branded fuel rail
800/1000cc injectors
-8 fuel line from tank splitting into 2x-6 at rail
-8 line from rail to reg
-8 from reg to tank
:D
alloy fuel tank
carter lift pump
aeromotive filters
2ltr surge tank
-8 from reg to tank
finally...
Does all thats stuff look nice?
Probably the most important thing about getting things you dont need, gotta look the part even if they dont do much more than the stock stuff :D
Kinda like a aftermarket BOV really, not needed... but makes noises and looks cool.
Probably the most important thing about getting things you dont need, gotta look the part even if they dont do much more than the stock stuff :)
stupidest comment ever :rolleyes:
Well how about you put the costings up for all the parts that you simply dont need.
Then we'll cost up something that could
1. Have far more use/benefit for the car
2. Return far more power/response
And so the list goes.
The factory gear has been proven time and time again to be faultless and totally reliable in big horsepower applications.
So i fail to logically see the need to waste money on paraphernalia type items that don't offer ANY usable gain over factory gear.
If anything, changing factory parts that are tried and proven, brings in the element of reliability using non factory parts!
I mean fair enough, if you have ALL the money in the world, you'd get stuff like that.
However, this is the real world, people real have budgets to build cars on. When your spending 15k on a rebuild, turbos, diffs, clutches etc.
Modifications that offer no tangible gain, do not fit into a budget.
that fuel system isnt for ur average run of the mill 400kw car, obviously, u musta missed my sarcasm that i wasnt aiming that guide to this thread specifically
Some may like to re-use the ~15yr old lines and that, but then some may like to replace it all with new parts, and not play with fire in a big hp application, to me its a no brainer
leave the original lines, the feed and return WILL be fine.
Id be fitting a surge tank, a 1 liter will be fine, its not like your planning any long high speed g forces.
Decent set of 700cc or there abouts injectors
Nismo fuel pressure reg to be safe
External bosch pump and use the stocker as a lift
Or just fit an intake bosch, with injectors and reg.
There is no need to upgrade lines etc etc for what you want to do.
If you cant afford the HKS version of the T04z then you cant afford to set up a fuel system with the best and biggest parts.
i can afford a hks to4z u dont know my finance situation so those comments r complete and utter bullshit i just cant justify 1850 dollars extra for a turbo that will prolly bring on boost 100rpm earlier and make around the same power as a garret.....
money for parts isnt the issue i will do it right no matter wat it costs
seems this thread has gone to the shit. I dont know too much on fuel systems but dude if i was you i would look around on carsales and stuff and find other high hp cars and see what they are using. Or even better ring up a few companys that sell fuel pump etc..
hey guys,
keep it up! lol
just invading this thread since everyone doesnt seem to have something to do.
does the fuel pump really makes a difference?
i am looking to achieve 350 to 400hp atw.
would a 600hp fuel pump be over kill. prices are not a huge difference. so should i just get a 600hp fuel pump?
thanks!
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
