Just wondering if anyone could tell me from there experience what brand electronic boost controllers are good. Are Blitz better than greddy? or should i go all out and get an apexi avc. i basically want something that is easy to use and has a digital display. Any help would be great..
^ yep x2
Eboost2 ftw !!!
Gate pressure settings, sensitivity settings, 6 preset boost, lauch control, boost and rev recall, boost gauge and controller in 1, looks neat and a ease 2 fit and use.
over boost shut down, warning lights and sounds when reaching high boost.
Haha u would think i work for turbosmart >_<
2 months ago i had a power fc fitted and wanted a suitable boost controller to suit... i settled with the avcr.. had my ash tray removed and fitted it there... ive never been happier with a boost controller... it is expensive but that little blue screen tells me what i need to know and can change between 3 boost settings in about 3 seconds! took a while to get used to but hell its great! and once learnt easy to use. has functions that i dont even use but if i ever get real serious there there for future use! if u have a apexi power fc i say go with the avcr. installation was relitively simple and the electronic valve sits near my filters.
good luck!!
I was thinking apexi soinoid plug as i have a power fc but i want funtions like scramble and graghs. peak settings ect. thinking of Blitz SBC 3. Has anyone used this type, how do they rate ?
I've got a Blitz SBC I-Colour and it's a pretty handy little unit.
Tons of functions and i've never had a problem with it.
Oh finding an english manual was the hard part but not cause i was installing it just for my use afterwards.
a bit of a side step but im using a VAFC as a boost guage for my car
it displays like the AVCR in guage and digital and digital tacho emulation format
but it lets you choose between the scale and measurment
i can choose between 0 to 15psi or 15psi to 30psi
and lets me choose PSI, MMHG/KGCM2 and KPA
Had a Profec B Spec 2, loved the ease of use, but hated the lack of full functionality and not being able to set psi boost that it would actively try to reach. Just bought an AVCR yet to see it in action, but sure it will meet my expectations.
You want something with a Dual Solenoid.
Single solenoid items are harder to setup, and at times do not perform as well as a dual.
A AVC-R is a single... Blitz, HKS etc are duals.
Often dual are more expensive, but you get what you pay for in that regard
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
