As a few of you know me and my neighbour will be running a SSS Pulsar in topgear events and hillclimbs etc.
Car was bought off MY105.com. At present it has the previous drivers designs (you can see it in the 'show me ur race machines' thread).
Who do we need to notify of any changes? Whats the procedure for having a numberr changed, or are they allocated? I know there are some things you need to keep eg tow point indicators, kill switch indicator etc.
We are looking at using the same colourrs (white car wtih red, blue and yellow livery) just updating it a little.
Any info would be great thanks!!
Rob
Im fairly sure for seasons, the numbers are allocated.
Well, thats for some clubs that do sprints with other clubs that are run with CAMS.
(My number from the SSCC was allocated to me)
If you are doing the CAMS hillclimb series etc, if you register at the start of the season they would issue you one, otherwise if its one hillclimb here, a sprint there, you just get a number on the day AFAIK
As for the series like Duncan races in - dunno, we'll wait for him to reply :rolleyes:
In this instance CAMS is your friend :P
Here's details on the required shtickers and placements:
http://www.camsmanual.com.au/pdf/general/0...%20k%20q108.pdf
Kill Switch/Tow Points etc are pretty straight forward- you put them where they are!
http://www.camsmanual.com.au/pdf/speed/100...regs%20q108.pdf
Race numbes are not issued by CAMS.
If you're running in a series (like Combined Tourers) the club organising the series issues numbers at the start of the season- you basically apply for the one you want and hope it's available. Sometimes the organisers reserve numbers (like 1- to give to the previous season's winner) but basically it's as straight forward as that.
As Chris has said, it works pretty much the same way with something like the Hillclimb championships though the rounds are run by individual clubs so you can sometimes have number conflicts. When this happens the trick is to add a '1' to your number e.g. 32 becomes 132 or 321- that way you don't have to change the permanant numbers on your car.
Changes to colour schemes are trickier. Officially, if your car is log booked, you need to notify CAMS when you make changes to colour/ design- not that I know anyone who has actually done this!
    • Hey everyone. Is there a way I can get the original window sticker (maroney label) for my 1995 R33 GTST? I doubt I’ll be able to ever get it but it’s worth a shot to ask
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
