  • Replies 607
Posted Images
hey are we cruising to the dyno day or are we splitting up so as not to draw attention to ourselves
Hmmm I am hoping to be there early cause helping out, but I have been lump with someone else crap to get rid of so see how I go :D
Woo.. cruising to campbelltown aye...
will let you know if i can make it.
If not, i'll let you know either way yeah... :rofl:
Hi Anna :down:
Hope you come will be good to have another girl on the track so we can beat the boys :(
gp challenge looks great but im up for anything.
never been go-karting before!
Yeah GP sound like the GO, Its great fun you will love it!!!
Me and bard are in for GP :)
BAM ON!! :laughing-smiley-014:
I am stocked up now, from my episode on Wednesday...That stuff was definately what I needed to attack that grime....*shudders*
So GP it is, do we have 10 entering!!!!! :D
Guest Joeyz
If not, i'll let you know either way yeah... :D
Top's Anna, even if you just come for the cruise and watch us all act like 4 year olds. Fun Fun Fun :D
Your kidding Albert, There is always a first for everything :laugh:
I'm up for GP, sounds like heaps of fun.
I'll have to remember the BAM! :bunny: lol
Make sure you have enough to bam all the Go-Kart seats, You never know :P
hey everyone,
sorry i haven't replyed i'm in bexley, an their internet is real slow hey :D
i'm in for sure :laugh:
jess if there is any info u need just msg my phone cause i prob won't be on here till late next week, cheers..
hey everyone,
sorry i haven't replyed i'm in bexley, an their internet is real slow hey :)
Oh your still there! :)
Good stuff is Leonie going to race aswell???
I hope so, or the boys are going to gang up on me :)
Yep will let you know any info :)
Joeyz can you book us in, please at Picton to secure the track and let us know what time we need to get to Picton karts by...
P.s everyone has to get out of bed on time!!!!! :)
Oh your still there! :wave:
I hope so, or the boys are going to gang up on me :yes:
Yep will let you know any info :P
No, she said she doesn't want to but she'll be there to cheer u on :D
thanks :D
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
