Hey all,
As many of you prolly know from my other current thread i've just installed a fmic on my r33.
My problem is to with my cars idling. I have done some searching through the forum about the whole need to retune thing and i would have to say the overwhelming majority say that there is no point in a retune if its simply just the fmic upgraded and nothing else (eg. no increase of boost)
So having said that why would my car run rough when it idles straight after start up?
Then if I go for a drive the car performs perfectly fine until u let the revs drop completely (like when u come to stop). The revs just continue to drop beyond the idle point and the car stalls!?
My car would randomly do this maybe once every couple weeks before the install so i just figured my aac valve failed occasionally. but now its non stop the car wont idle after being on higher revs.
So at the end of all this what do people think is wrong.
could it be that during the many days my cars been off the road the aac valve has become stuck closed.
could it be an air leak in the new piping for the fmic (but i would have thought this would cause problems all the way through the rev range like not hitting previous boost levels due to pressure loss)
or potentially does my power fc need some tlc at the tuners?
any help would be much appreciated as i want to be able to drive my car asap. (currently i'm getting around in a early 90's volvo and every time people see me in it a die a little inside ;))
Cheers
Camden
https://www.sau.com.au/forums/topic/201405-fmic-idle/
Test it by getting another AFM and seein if it still happens, i replaced mine recently and did the trick, if the change over aFM doesnt do ur car any just , there is a good AAC valve cleaning thread some where on here really handy...
https://www.sau.com.au/forums/topic/201405-fmic-idle/#findComment-3579934
Yeah mate i did see that thread about the aac. Thinking i might give that a burl tonight as well as just giving my afm a clean out with some contact cleaner.
Only thing im a bit unsure about is doing the whole idle point reset as im not using the stock ecu anymore (power fc)
Cheers
Camden
https://www.sau.com.au/forums/topic/201405-fmic-idle/#findComment-3580076
as in its just dirty or u recon it might need replacing?
is there a method of testing the afm? i don't really want to go out and buy one to find its not the problem.
know anyone that you can borrow from?
https://www.sau.com.au/forums/topic/201405-fmic-idle/#findComment-3581067
Test each of these one at a time so you know what the culprit is.
1. tighten all clamps again
2. adjust the screw on the IAC valve while the car is idling, see if you can find a smooth idle point.
3. Clean afm
4. Check that no vacuum hoses have removed and not put back on during installation i.e. to charcoal canister.
5. Pressurize the intercooler piping, look for any leaks.
https://www.sau.com.au/forums/topic/201405-fmic-idle/#findComment-3581364
Well i attacked the AFM and its connector with some contact cleaner yesterday and it seems to have made a difference. car doesn't stall anymore and in general drives fine but sometimes when coming down in revs it still drops a little low to then bounce back up to where it should idle at.
I've also noticed the car seems to be running quite rich as there is a lot of black splatter all over the arse of my car.
https://www.sau.com.au/forums/topic/201405-fmic-idle/#findComment-3583948
on start up does the car still run rough or has this stopped completely? doesnt stall anymore? thats good if its problem fixed.
as for running rich, stick the car on a dyno and get it tuned again. imo a power fc doesnt learn like a standard computer, so a tune will be needed (correct me if im wrong). since it was tuned for a small side mount it only expects so much and now your cooling alot more air in a larger space.
my 2cents
https://www.sau.com.au/forums/topic/201405-fmic-idle/#findComment-3584418
my 2cents
It starts up fine now.. and doesn't stall anymore, sorta. On letting the revs drop back towards idle it still goes to far, the car then kinda stuggles for second and then kick back to the correct idle position.
And yes the Power fc isnt going to protect its self etc like the stock computer. But something is causing the maps to be wrong and its running really friggin rich.. the whole back of my car is getting covered in black shite. Will def be back for a tune when i get free second (DAMN YOU WORK!)
Cheers
Camden
https://www.sau.com.au/forums/topic/201405-fmic-idle/#findComment-3590719
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
