just another note - i dunno about the difference with hi flo cats - havent read that much about em really...
my order of mods is (with the pod air filter done - have you done that?) cat back mandrel bent system, extractors, spark plugs (i know not really a mod but hey), timing, apexi super-AFC II, hi flo cat (?)
  • Replies 82
extractors definately a worth while mod, and the best value for money i can recomend. I will be selling just about everything early next year, including the s-afc ii due to the new engine, and mods to my current engine have now ceased other then i dyno tune i hope to do in the next few weeks, its just hard to find spare time and money while at school.
Dam guys where do u get your $$ from, prehapes i dont want to know.
anyway i should be getting my N/A soon, i will happly buy any parts you have up for graps when your new engine come along na_r33. even though i live in melbourne i cant stand in the way of a possible bargan.
plz tell me the dino results so i can prove to my mates i dont need turbo....
lol work my arse off, lol think i will have to get some more hours at "TARGET" box hill to support my car. And go to TAFE (Sad i know)
i will getting my N/A a soon as i sell my holden vr berlina.
then watch out ladies becasue their will be a new player in town. lol
cant wait to ge my skyline only down side atm is the insurance aspect of things, but hey what can u do about it.
best option i now belive is an engine imobiliser i had one on my first car and try to steal it myself and had no luck an auto elec mate told my once they are imobilised the system has to be taken out completely to get the car to run which can take hours if they can even find it depending on if its an aftermarket model or stocko or install a kill switch, all these thing i should have done to start with (stupid me)
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
