just another note - i dunno about the difference with hi flo cats - havent read that much about em really...
my order of mods is (with the pod air filter done - have you done that?) cat back mandrel bent system, extractors, spark plugs (i know not really a mod but hey), timing, apexi super-AFC II, hi flo cat (?)
  • Replies 82
extractors definately a worth while mod, and the best value for money i can recomend. I will be selling just about everything early next year, including the s-afc ii due to the new engine, and mods to my current engine have now ceased other then i dyno tune i hope to do in the next few weeks, its just hard to find spare time and money while at school.
Dam guys where do u get your $$ from, prehapes i dont want to know.
anyway i should be getting my N/A soon, i will happly buy any parts you have up for graps when your new engine come along na_r33. even though i live in melbourne i cant stand in the way of a possible bargan.
plz tell me the dino results so i can prove to my mates i dont need turbo....
lol work my arse off, lol think i will have to get some more hours at "TARGET" box hill to support my car. And go to TAFE (Sad i know)
i will getting my N/A a soon as i sell my holden vr berlina.
then watch out ladies becasue their will be a new player in town. lol
cant wait to ge my skyline only down side atm is the insurance aspect of things, but hey what can u do about it.
best option i now belive is an engine imobiliser i had one on my first car and try to steal it myself and had no luck an auto elec mate told my once they are imobilised the system has to be taken out completely to get the car to run which can take hours if they can even find it depending on if its an aftermarket model or stocko or install a kill switch, all these thing i should have done to start with (stupid me)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
