check out what has just entered the 5lt class of circuit boat racing that i compete in (in daddys 600hp chev powered boat).
think he might be taking home some trophys in not too distant future!
brett
http://au.youtube.com/watch?v=9eiTaKq9nrs&...feature=related
https://www.sau.com.au/forums/topic/201945-1100hp-2jz-in-boat/
brett
sounds like Paul talking and looks like Bruce Sanders spending some more $$ on more toys, at Raymond Terrace too!
engine is built by gas motorsport, same guys that have a 6second 2jz in a drag car, pretty dam impressive. interested to know what an engine like that would cost to build cause we have just spent 30k on a 5lt chev that will dyno just over 600hp. cant imaging a 2jz could be a heap more that that with twice the amount of stick
You'll find a lot of stuff probably came out of the US, so it wouldnt be overtly expensive as there is a lot of support for 2JZ's over there.
Building a 600hp N/A and a 600hp 2JZ are far away... a 2JZ will do 600hp on a factory motor with just bolt ons... so less than 10k
I thought that was at the terrace! lol was gona ask you beat me to it :)
Will give the VG30 twin turbo a ass wooping ;)
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
