Ok guys its a pretty simple question but after searching couldnt really get an answer.
All i want to know is will the AFC neo support 250rwkw along with all the other necessary mods?
Or is it necessary to use an EMU or other....
250rwkw is my goal over the next few years so want something that will support it from the beginning.
Thanks guys!
https://www.sau.com.au/forums/topic/201968-afc-neo/
Thanks guys!
Won't 'support' very well at all.
Power FC is your answer in the Apexi range of products.
End of story. :P
https://www.sau.com.au/forums/topic/201968-afc-neo/#findComment-3588353
The engine management system is what controls how much fuel and air goes into the engine. Get it wrong, and stuff breaks. Expensive stuff. $1500 is a relatively small price to pay for good economy, emissions, power and reliability.
What other systems would you consider aside from a PowerFC?
Don't forget to factor in the cost of tuning. The PowerFC is a very well known computer, so programming it won't cost as much as more esoteric hardware. If you retune after every powertrain mod (which you should technically do) then the lower cost of tuning will put the PFC cheaper when you're talking Total Cost of Ownership.
https://www.sau.com.au/forums/topic/201968-afc-neo/#findComment-3589929
Unless someone has a reason why the pfc is $700 better than the EMU?
It has a funky looking hand controller? :(
Power FC questions and answers that way ------------------------> http://www.skylinesaustralia.com/forums/Fa...req-t64201.html
https://www.sau.com.au/forums/topic/201968-afc-neo/#findComment-3590613
i had in my 33 a safc2 and emanage (not at the same time), and before i got rid of it i tested a power fc out in my car for a mate who bought 1 for his build, was already tuned for similar mods to my car, and it shat all over both the previous systems i had.
i got a 34 now and i wont be getting anything other than a pfc.
also 1500 is if u want a new 1, u can get 1 for a rb25det for about 900-1000 second hand no hand controller. u dont need the controller to tune as tuners just plug in a lap top or if u do it.
my 2 cents
https://www.sau.com.au/forums/topic/201968-afc-neo/#findComment-3590640
Thanks for that daniel, thats the kind of advise i like....personal experience. Especially when you have used all three of the ecu's i have been contemplating! I think its time i start searching for a 2nd hand pfc!
Thanks for all your help guys! :D
https://www.sau.com.au/forums/topic/201968-afc-neo/#findComment-3591379
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
