yesterday I put on a hks pod filter on my stock r33 series II. and blocked the hose going in to the stock blowoff valve (a mate told me it would sound mad) it actually sounds like a wrx in a way (I suggest trying it).
but ever since i put the car in this configuration, I feel a loss of power. any suggestions on why this is happening??
I thought that I should get an increase in power just by putting the pod on!!!
I thought about it and I'm thinking that maybe the standard exhaust is not copping with the amount of air that going in.
I didn't reset the ecu, i wouldn't have thought that it would be that bigger difference. I could be wrong??
anyway any suggestions would be welcome.
https://www.sau.com.au/forums/topic/2020-pod-filter-probs/
Dood, if you'be blocked the hose running out of the stock BOV that means that basically you are not using a BOV at all..which is a very very bad thing to do..hurts ya turbo a lot heeh
and yeah a simple air filter wont nab you any free power...
exhaust would though...
mc
:shake:
https://www.sau.com.au/forums/topic/2020-pod-filter-probs/#findComment-37516
if the hose you blocked is the little one leading from the plenum then you problem is that the standard BOV blows open at about 5psi without this little hose connected
so thats where you loose your power the spring alone isnt strong enough to keep it closed on its own it needs the pressure that comes i from that hose to help it stay shut
https://www.sau.com.au/forums/topic/2020-pod-filter-probs/#findComment-37616
Stop hot air getting in there and you might notice a slight improvement.?!?!?!
I'm not going to worry about going a pod filter.
It didn't show any power gain (1rwkw wow) on the dyno compared to the std air box with a bigger cold air intake and decent panel filter.
It might show more of a power increase when I start getting up around the 200rwkw mark btw.
https://www.sau.com.au/forums/topic/2020-pod-filter-probs/#findComment-38975
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
