hey all, just wondering what your predictions are for my new donk. should be rolling out hopefully tomorrow or monday at worst. oh the suspense after sitting in the driveway for 4 months!
R33 GTS25t
-pod
-3in exhaust (possibly dump as well, output seems pretty good)
177rwkw
now with:
-replacement engine
-kkr430 turbo
-fmic
-forward facing plenum
-440cc injectors
-fuel pump
-bov
im thinking ill go for 13-14 psi boost. and am hoping for at least 200rwkw, optimistically 210. what do you think?
also, 1/4 mile on 255 bridgestones? im thinking 13.3? am i having a wank dreaming of 13.0?
haha appreciate any input. bear in mind this is the 2nd engine ive had to replace in 9 months so funds for bigger mods have been hard to come by.
i am looking forward to pulling apart my wrecked motor, some may remember it getting a compression test of 0psi in one of the cylinders. so i might post some pics when i get stuck into that. also, im hoping the head is fine so there might be a few bits for sale soon.
thanks guys!
https://www.sau.com.au/forums/topic/202079-performance-predictions/
i have read that on an r33 the KKR480 was good for 270RWKW at 18psi, i 'd say the 200-210 make your thinking would be about right.. if not slightly higher..
are you running some sort of piggy back ECU or full aftermarket??
Well a bonnet down 177rwkw is a high 12 over the 1/4 if you have something remotely wide tyre wise on the rear and you have by a long way. I'd say if that pod filter has no cold air partition and feed the 177 is more like 150 realistically on the road.
You have aftermarket engine management right?
If drag racing is something you want to have a go at then things like some pineapples for the rear diff cradle wouldn't hurt and hopefully you have an upgraded clutch in there too.
A 12 should be so easy it isn't funny if you are making a genuine 210rwkw bonnet down.
:D
thats alright! but mines a 430, not a 480 :D
well, no im strapped for cash, so im remapping the stocko ecu. which is not ideal i realise, but i will get a pfc by my 21st in july hopefully.
wha? the pod doesnt have a box or anything, though if you think its wasting that much power i might have to make something up! surely its not worth 25kw though? :D
yeh as i said above, remapping stocko ecu because i havent got the cash atm. but i will go pfc for sure.
im not really that into the drags, but i would like to know my times just so i can ram them up my commo-loving mates. not sure how long the clutch will last though :D but my tyres seem to develop a lot of traction certainly compared to the ones i had previously (theyd bloody want to for $425 each)
12s!! sweet as!
12s!! sweet as!
Yep it's worth a fair whack alright. The engine bay air is often 70+deg C around town on a hot day it's hotter again, it's not a good thing really.
If you are getting a full remap (fuel and ignition) then thats fine although I thought the R33 remaps were as pricey as a powerFC?
It's 12's when you actually do it on the strip. Not a lot of point talking about how fast your car is going to be but, rather just go and see. :D
wow. thats some hot air. so what do you have to do? shield the pod from the engine bay, with plastic or something? heat wrap? or redirect it somehow so its drawing cooler air?
i have been told they charge hourly rate to do ecu's, which should equate to maybe $3-400 at worst. i dont see how it could cost more than that! it would be a waste of time if it did.
know that, that why i said around the 200 -210rwkw mark, i didn't think there was anyone re-mapping the r33 ECU? and charging by the hour sounds more like dyno time then re-mapping the ECU?
may be an SAFC / SAFC 2 could be a good cheaper option than the re-map? you should be able to get a good second hand one for $200-250 then at a good tuner maybe and hours tune.. $100-150... you can also re-sale the safc once you get the PFC hehehe..
Good luck finding a pfc.................
There impossible to fine
well brand new i mean...............And you dont wanna get them second hand....
Btw with your turbo you will have shit load of lag
Warlord You got luck bro..................
You never know what is wrong with the unit when it is second hand .....
there has been alot of story of people buying dud
I think it is time you look at others than the Pfc
dont get me wrong the PFC is the best ................... But now there is better
I've never heard of a 'dud' power FC purchase to date, not that it may not happen, just seems to be by far the exception ot the rule.
Searching this forum you struggle to find someone complaining of a dud purchase....
rev m8...............................
I bought a brand new PFC in novemeber and it was a dud.....Luckly i bought it from a dealer so there for i go my money back. there has been heaps of story of pfc being duds and yeah for tuners.........................these are computers the bound to be faulty
Anyway i hav now in my car an EMS 8860................. it is rated highly and my car is done at bel garage and the masters at tuning....
Pfc are still the best comps around but the becoming rare.
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
    • That's some really horrible design with the way it's cut/shaped! Is there much damage to the box that failed in? IE, new fork and you can go again, or is it a total rebuild again? Id be trying to build that piece from scratch, and getting some reliefs added in the corner to hopefully stop breakage, and then swapping boxes ASAP, and then doing the same to the currently good working box. I'm assuming hard shifts have not been friendly to it!
