hey guys, just a quick question, i gotta s2 33gts4 and looking to do a 5 stud conversion however i don't want to spend too much as i am only doing it so i can find bigger rims, my question is, if i just fit the hubs + rotors off a 33 gtst, would i also need to get bigger calipers aswell? would the stock calipers still work ok? i understand if i get bigger calipers i will need a another brake booster which leads to more money lol.
also would just changing the hubs + rotors on the rear brakes be the same?
Edited by OoskylineoO
https://www.sau.com.au/forums/topic/202120-5-stud-hubs/
  • Replies 45
the larger diameter rotors will not fit your original calipers.
larger brake booster is ideal yes.
you might need to do some mods to get your inner drum handbrake to work with new rotors (rear)
Hey Eug! because i am doing 5-stud conversion with gts-t rotors and calipers does this mean i also need to get a larger brake booster?
OoskylineoO if i were you i'd be getting the gts-t calipers as well unless you don't want to be spending too muc money you could be blank GTS4 rotors and have them drilled to the 5-stud pattern, so you can use your original calipers..
cheers hame :D
https://www.sau.com.au/forums/topic/202120-5-stud-hubs/#findComment-3590710
NA Skylines have the same stud patterns as S13 Silvias and 180SXs, right? Then theoretically you can use the conversion plates or what ever they are to convert the stud pattern. Is this possible? Or does it mess around with the off-set to much? Just thought it would be easier and cheaper this way
https://www.sau.com.au/forums/topic/202120-5-stud-hubs/#findComment-3592095
hey,
im not 100% sure but i think u have to get front hubs off a fwd skyline/stagea. i was gonna do the same thing on my gts4 but everywhere i went said 100bucks so if i end up doin it i will jus redrill the hubs. my mate got it done and it worked a treat. nice and cheap too
https://www.sau.com.au/forums/topic/202120-5-stud-hubs/#findComment-3611062
hey mate,
name's Adam
I have an r33 gts4-t s1.... in the next few days mine is going to be converted to 5 stud... (i converted mine to turbo about 8 months ago)
you WILL need r33 gtr parts for the front, othernwise the awd system wont work...
I have a suggestion for you.... why not do what I am doing and buy the entire front gtr arms? I know they are hard to find... but its a sh*tload easier... because I have already bought some gtst calipers and rotors and have now fitted them onto the arms.. and now I only need to undo about 3 massive bolts and 3 small ones on the car, pull off the current entire arm with old rotors, calipers, etc still attached.lubricate the appropriate areas, bleed the brakes, bolt everything up and hey presto.. I have 5 studs at the front...
interms of the rear.. unless you already have a hicas lock bar installed or know what you are doing, I would not advise to do it, because I am told that if you take off everything in the rear, right down to hubs( to change them over obveously) the hicas steering stuffs up and you will end up crab walking. thats why I am paying someone else to do the rear ( which is only $250 labour)
also.. don't bother re drilling your current stuff to fit, it will probably cost more and alot more effort to do then just spending 200-300 buying someone else's rotors and callipers.
i looked around on this website and I bought a full set of turbo callipers for roughly $120- $150 ? and 50 bux for a full set of rotors that have plenty meat left on them...
so think about a few other options. :banana:
Regards,
Adam
https://www.sau.com.au/forums/topic/202120-5-stud-hubs/#findComment-3613388
alright well here i go......well basically i had in mind of this i converted my car to turbo ...its a R33 GTS S1....i bought Turbo front rotors got them professionally redrilled to 4 stud slapped them on the front and i did the same for the rear but a work shops going to put them on so yeah i didn't have to go to the extent in buying new rims etc etc :D redrilling costed me 40 for 2 front rotors and yes must upgrade brake booster :D hehe i woudl well im goign to :banana:
https://www.sau.com.au/forums/topic/202120-5-stud-hubs/#findComment-3613432
alright well here i go......well basically i had in mind of this i converted my car to turbo ...its a R33 GTS S1....i bought Turbo front rotors got them professionally redrilled to 4 stud slapped them on the front and i did the same for the rear but a work shops going to put them on so yeah i didn't have to go to the extent in buying new rims etc etc :w00t: redrilling costed me 40 for 2 front rotors and yes must upgrade brake booster :D hehe i woudl well im goign to :banana:
Ahh cool, i doing the conversion as well but don't want to buy new rims (alothough i put them up for sale, to see what'd happen) check my user name. So where did u get the rotors redrilled? hame >_<
https://www.sau.com.au/forums/topic/202120-5-stud-hubs/#findComment-3615290
hey mate,
name's Adam
Regards,
Adam
mmm, would I HAVE TO by the front arms off a r33 gtr?, how much would they cost?. Basically converting a 33gts4 to 5stud i would need 33 gtr rotors, calipers and hubs for the front? do I also need brake cylinder and booster off a gtr? or will a gtst 1 do? what about the back? would a set of hubs calipers and rotors off a gtst do? any adjustments of the hand brake?
sorry, imma bit of a noob with this ><
https://www.sau.com.au/forums/topic/202120-5-stud-hubs/#findComment-3623467
Lol, dw mate, im noob too.... just played around with these things a lil and done some research
I pretty much did the front myself, but I have an exam in 3 days and i lost time, so I ended up putting it all back together ( well enough to drive a km) and took it to the tuners and spent the extra $150 getting them to do the front aswell... wasent that much in the end....
Car is running great atm, no probs at all.. looks sweet... rims soon enough, after I get a new turbo...
onto ur q's...
1.If u were to buy arms they would have to be off a gtr, or a gts4 converted to a 5 stud, possibly stega?not 100% sure but I thought some of them are AWD aswell...
you could buy mine that are now off the car and for sale and get some gtst front hubs and convert them easily while off the car.(hint hint :) )
2. I paid a fair coin for the 33 gtr arms... can't remeber exactly.. but I think in the region of $500.. but mine were mint, barely any rust etc.. don't know how much you could find them for, very hard to find in the first instance!
3. you don't need the 33 gtr rotors,calipers and hubs for the front, I used all 33 gtst gear and was perfect. (I picked up all the rotors for 50 bux and full set of calipers with some pads on them for $200)
4. I was worried about the brake cylinder/booster problem as well... was absolutely fine on my car.. I don't know what the fuss is all about.. it is exactly the same...
5. for the back.. I paid 250 for the hubs and I already mentioned the rotors and calipers.
6. nothing has happend to the handbrake, what are you worried about?
hope this helps.
Adam
https://www.sau.com.au/forums/topic/202120-5-stud-hubs/#findComment-3638417
Just for a bit of side info, my r34 gtfour uses the exact same calipers and brake pads as the na r33, but mine is 5 stud. So if you managed to get the 5 stud hubs, you could just order my rotors then you can keep your stock calipers and pads.
Of course you wont be "upgrading" your braking abilities, but if your just chasing the 5 stud for rim purposes then this maybe cheaper for you.
https://www.sau.com.au/forums/topic/202120-5-stud-hubs/#findComment-3649987
that's a very interesting tip!
most 4 stud rims won't clear the bigger brakes anyway.
https://www.sau.com.au/forums/topic/202120-5-stud-hubs/#findComment-3650236
thanks for the write up, so your saying i wouldn't need r33 gtr parts at all?, simply just all hubs, rotors, calipers from a gtst, bring them all to mechanic and let the do the work?
Well, estentially, yes.
I think the reason I went with the whole arms on the front was just because it was abit cheaper or the same price to change the whole arm as oppose to just the studs, also because it was a stroke of luck that they happend to have a 33 gtr front half cut at the time...
https://www.sau.com.au/forums/topic/202120-5-stud-hubs/#findComment-3650606
  • 3 weeks later...
Thanks!,
If the conversion is done for the rear, would it definately stuff the HICAS steering?, if it is true can anybody recommend me a mechanic in sydney that would KNOW what they are dealing with when doing the conversion?
https://www.sau.com.au/forums/topic/202120-5-stud-hubs/#findComment-3693376
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
