Can any one help? There was a pair of 210 hot plates on ebay a couple of weeks ago that sold for around $750... did anyone on here buy them?
Some guy just bumped into the back of my bro's car & they managed to crack one of the lenses. Of course the guy was driving a crap box, with no insurance, & 'doesn't speeka da englase'. :)
If someone on here bought them, or knows who did, I might need to get a copy of the invoice or something to show how much they are worth.
I know there is a set for a late/211 on ebay now for $350, but they are a different shape to what he's got. He paid alot more than that for his too, but has recently moved house, and can't find the invoice papers for them anywhere.
So, yeah, if the guy turns out to be a pain & doesn't want to cough up the cash, an invoice might help.
cheers.
https://www.sau.com.au/forums/topic/202262-210-hot-plates/
Hey mate,
They $770 set went to a guy named Ralf in Germany, who is doing an amazing restoration on a red C210. Oddly, no-one bid on an identical set listed for $550. There are more sets readily available on Yahoo auctions Japan, some going quite cheaply, although you will have to ask around politely in the Japan forum to find someone in Japan willing to bid and post on your behalf. NO-ONE ships internationally from Yahoo Japan. Grr.
Which lense got broken? I have some semi-smashed up hotplates and may be able to salvage the lense you need anyway.
Cheers,
D
https://www.sau.com.au/forums/topic/202262-210-hot-plates/#findComment-3595348
Hey mate,
Cheers,
D
Yeah, I've never really been involved with yahoo jp anyway...
If you've got bit n pieces, that would be tops! Its the left hand tail light, the red ring lense on the numberplate side.
Not sure if they come apart of fit from side to side or whatever, so not too keen to bid on the 211 ones on ebay atm either.
So yeah, if you can help out with a lense my bro would be stoked.
Cheers,
Michael.
p.s. those jap mirrors & gt's I got off ya look trick on the car too
https://www.sau.com.au/forums/topic/202262-210-hot-plates/#findComment-3596876
Great news about the mirrors and badges and I'm more than happy to help with the lense. I'll try pulling the smashed one apart on the weekend. No promises though, all the wrong bits may be busted!
Ill get back to you shortly,
D
https://www.sau.com.au/forums/topic/202262-210-hot-plates/#findComment-3597562
Those JDM lights on ebay are $250 down from $350. That's getting a little more realistic now - especially seeing the chrome trim around the outer edge of the plastic hasn't dissolved into a brown ring of rust yet... Like mine. Shame they don't come with the centre garnish though.
https://www.sau.com.au/forums/topic/202262-210-hot-plates/#findComment-3599012
Does this look right? How does $35 sound?
Cheers
sorry about the late reply, work..sleep..work..sleep..
Does that centre reflector part come out? My bro's has a reverse light white/clear centre(which isn't broken)
cheers,
Michael.
https://www.sau.com.au/forums/topic/202262-210-hot-plates/#findComment-3621110
hey hey,
I had a play with it and although there is a (seemingly useless) screw that I removed the centre part doesn't seem to budge. I didn't want to push to hard on it though as I'm kind of prone to breaking stuff. I don't see how it can be removed easily though. Maybe it's glued in place. The lights that this lense is from has the reverse light as a separate rectangular lense.
Cheers,
D
https://www.sau.com.au/forums/topic/202262-210-hot-plates/#findComment-3621276
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
