For sale:
RB26dett built about 2 years ago by benny at hi torque but built just previous to hi torque.
engine has full new crank
forged pistons
big cams
garrrett 2560r turbos
n1 pumps
modified ignition
ported head
metal head gasket
head stud bolts tomei
ehxasust manifolds
makes easy 350kw at all four wheels on pump fuel all day
all receits for the engine build nearly $20,000 for the build alone
also comes with apexi power fc
and excceedy triple plate clutch valued another $3000.
This packagae is a cheaper and easier solution for anyone wanting more power i have all photos of the build
and the engine is currently in the car
reason for sale is simple RB32 is planned.
the plan is to sell the entire package as is leaving the bottom diff / sump in the car.
GREAT VALUE.........
i also have an N1 block for sale brand new. make and offer.
all enquiries please call 0405385519 or email [email protected] for photos coming soon.
Attached thumbnail(s)14000, ONO
or
15k with clutch and fc
ONO.
Edited by tribex
Where did you get engine ported?
what was the before an after port bench flow test results?
Is the valve train still standard OEM items?
What rods and what rod bearings did you use?
What big end bearings etc did you use in build?
cheers mate...
Also what gaskets did you use in build?
cheers mate...
cp forged pistons
rev conrods
new crank at time of rebuild
cp rings
ACL race bearings
main stud kit
head stud kit
tomei steel head gasket
tomei poncams
tomei valve springs
tomei camgears
genuine gaskets and seals
trust exhaust manifolds
trust dump pipes
garrett -8 ball bearing turbos
sard 800cc injectors
fuel pressure regulator
gates race timing belt
n1 oil pump
n1 water pump
tomei sump baffle
blue printed and balanced
professionally assembled
engine currently makes 630hp (340kw at all four wheels)
can handle over 700hp with larger turbos
tripple plate exedy clutch
power fc
plus heaps more i probably havent listed!!!!
Edited by tribex
how mch mate, whast the price you are after????
i think the entire package 14000 ono. consider the build and parts alone over 20k and a standard good engine out of a late model 33 '97 would cost maybe 5k for the engine alone.
taking offers.....
taking offers.....
wowww......... that is bloody cheap, anywayone got a r32 gtr shell can spend another 15gz insetad of spending 25gz and get this entire mostrer package,
mate if i had a no engine in my gtr i would of ran for it,
gl wid sale, free BUMPPPPP
bump dont want to seperate may consider offers without turbos
pms sent
Generally helps to put it in your first post... using the pre-format thats given.
Hence it makes it clear for users/Admin alike.
DONE in first section thanks bump.
PS will not sell turbos until engine is sold if its sold without them thanks guys.
hey mate, interested in just the botom end and dont need the head or turbos, would seprate ? and how much u after ?
not really buddy i might sepearte the engine and the turbos and clucth and fc but i dont think i want toll the bottom end.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
