Hi All,
I've had these Items sitting on my shelf for some time, would be better of being put to use by someone else than just lying around the place.
Item: Apexi AVCR
Age: 6 months of use
Condition: Excellent
Price: $350 + postage
Contact: [email protected] or PM
Comments: This was originally installed in my S15 a few years ago, but took it out once i sold it. I was going to put it in my stagea, but now I have decided to keep it stock. Everything is included (orginal box, sensor, solenoid, wiring, clamps, hoses, stand etc...)
TURBO TIMER SOLD
Sorry about the crappy picture quality, was taken on my phone.
Yunis
Edited by Yunis
https://www.sau.com.au/forums/topic/202379-apexi-avcr-apexi-auto-timer/
Hey bud,
Turbo timer is sold.
sorry.
interested in the T/Timer.... item condition? age? will purchase next week, contact me at [email protected], could get more photos? closer pics? complete item
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
