Since we have all the corrupted sick stories still in our heads fresh from last yr why not spill them over a coffee meet with some food ..etc
Where: Coffee Club, Shop 1 1422 - 1428 Logan Rd, MT GRAVATT
When: Friday 25th Jan, 7pm
Encourage everyone and anyone no limited numbers etc.. can even turn up on the spot !
Anyone has any problems getting there feel free to contact me on 0400565607 cheers
Vish
Edited by 53XYN
https://www.sau.com.au/forums/topic/202559-friday-25th-coffee-meet/
alright guys for Stones Throw Cafe i need more then 10 people in otherwise like last time i would have to fork out booking fee myself unless of course someone buys me chais all nite lol
Let me know the numbers by thursday arvo latest ?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
