i think they are a lil overpriced...i would have thought the new VW Jetta would have got it as its quite cheap for all the goodies u get..but then i am biased as my dad just got the turbo one and its awsome lol but it beats my 32 :) time for mods :D
The exterior is very well designed, and i'm a fan of the interior also. They really look great on the road... haven't driven one though and i'm not likely to drive one any time soon. I'm sure they drive as well as they look.
They do look ok on the outside. Can't comment on the interior thought haven't seen it.
They said it was good value for money, because it had only gone up $700 in price (i think for the base model) since 10 years ago.
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
