Hey guys,
I've tried most online shops that sell body kits, but for the life of mine i could not find any front bar lip for the series 1 R33 ? Do you guys know where i can get one or maybe some one has one for sale ? Any help much appreciated!
cheers
vlad
https://www.sau.com.au/forums/topic/202866-r33-front-bar-lip/
well as far as i know or what i think i know....i have a lip on my front bar....now anyone please do tell me whether i am right or wrong....but i have looked at a few S1 front bars and mine just looks slightly different....
for some reason i cannot attach a picture so i have provided a link to another forum where pics of my car can be seen.....and you guys can tell me if i am correct about having a lip on it or not...
http://www.rpmlounge.com.au/forums/index.p...t=0&start=0
Yeah looks like a stock type M front bar, which doesn't look bad tho :)
Has anyone bought anything from these guys ?
http://www.newstylemotorsport.com/nissan/nissan_R33.php
I was looking into this front bar
$550 + delivery whatever will that be, overpriced ?
vlad
HOTWIRE......if you can see that where the stickers on the front bar are....thats a seperate unit from the front bar....if you have a close up look then its bolted on.....not saying i am right here but thats what it is....i will be at the Ben Simpson Memorial cruise so if you want come and have a look and will be glad to have a nice chat...
I see what you are talking about now, yup it appears there is a slight extension to the lip under the opening. :) Never seen that before, its quite subtle but looks good. I just saw the indicators, shape of the bar and the side flutes and thought "yep type M". I dont think that would bolt up to Krishy's non-type M bar though, but its an option for those with a type M bar.
I'll be at the BSM cruise this weekend, and would be good to catch up with you (and all other SAU'ers)
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
