(1)does anybody on here know how the the auto trans ecu communicates with the engine ecu.
(2)is there a trigger wire to signify an up shift or is there a series of information past to and from each ecu during the process of a gear change.
(3)does anybody by any chance have the pin outs of the auto ecu. i have the engine ecu pinouts but just need to find out how the two ecu's communicate. i have a friend at haltech who is going to try and determin if he can use the rpm based ignition retard flat shit map in nissan automatic vehicles. the map isnt load dependable but is programable at intervalls of 500rpm and will control ignition timing if a triger signal can be found.
there "could be" a new range of haltech ecu's coming out in the near future that will be an advancement in piggy back computing. instead of being wired into the loom before the ecu and altering or bending the signals ( dfa, sitc etc )from the standard sensors like our MAF signals. the new ecu's will also be able to be wired after the standard ecu and catch the ignition and injector signals and add correction values to them. allowing for full control of all engine requirements while still leaving the standard ecu in place to control procedures that are to hard to dupilcate when using a stand alone ecu.
i havent had my stagea long but im sick of reading about how everone has given up and put the idea of having a properly controlable ecu in an auto in the to hard basket. if i have to go and road test my car with a test light on or muli meter on every wire on the ecu i will but im hoping someone has the wiring diagrams somewhere.
But i didnt tell any of u guys about this. hint hint as its just hearsay atm
thanks heaps if u got this far as all ur help will be appreciated. im not going to rest until i get this or something to work so i can give us auto guys what we want.
Cheers dave
https://www.sau.com.au/forums/topic/202953-auto-ecu/
This is the ECU pin out schematic that I used;
http://members.iinet.net.au/~jay77/R34ECUpinouts.pdf
The engine ECU outputs/ inputs for auto trans are 34, 35, 38, 39, 40, 41, 52, 64, 65 and 66. Pin #52, #65 and #66 are the data transfer input/output for the auto trans, so they are the most likely.
My understanding is limited, but I have been told that the auto ecu signals the engine ecu when it is about the change gear. The engine ecu looks at the various parameters (rpm, kph, what gear, throttle position, engine temperature, AFM voltage etc) and then chooses an applicabe amount of igntion retard/cut from its 3 dimensional map. The mapping is supposed to be very complex to cover all circumstances (varieties of inputs).
My understanding is that Apexi looked at duplicating the mapping in their Power FC and found the cost to be prohibitive (ie; no one would pay the price). They did do it for Toyota autos, but they have the mapping in the auto ecu, not the engine ecu.
The Haltec piggy back scenario you describe is much like the EManage, HKS FCon and several others. Nothing new there.
Cheers
Gary
https://www.sau.com.au/forums/topic/202953-auto-ecu/#findComment-3601500
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
