I'm looking to source the rubber seal that seals between the drivers window and the small rear window on the C210 78 coupe or a substitute idea that someone may have done, a certain type of strip maybe. All ideas will be valued .Cheers Ricky
https://www.sau.com.au/forums/topic/203278-c210-rubber-bits/
Have you tried Rare Spares ?
http://www.rarespares.net.au/Parts-Accessories.aspx
Nigel
I'll have a rummage around and see if I can't find something for you. Failing that you can try Clark Rubber. They have an amazing selection of rubbery bits.
Drew
Cheers Drew, I've just looked at Rare Spares site. They list the type of strip I'm after but it's for the 240K, so whether these are similar, I'm not sure. I've sent them an email. I've handed my car over to some auto pros, had enough of stuffin around so it should finally be runnin in about 6 days ,all going well. Do you know of any other transplants that have been done to C210's other than L series conversions, such as V6 or Rb's?
Hey Ricky,
I'm hitting the workshop today so I'll let you know what I've found to suit tonight.
I know of a few swaps into C210's. V8 Skyline Man was running a... well you can probably guess, until someone hit his car, and another guy I know in Tasmania is selling off his Rb20 C210 sedan to fund an Rb26 C210 coupe project! I'm staying old-school though, and am building up a warm L28, as do most of the the guys with C210s and 240ks in my Japanese "Enjoy Retro Car" magazine have.
If you want to read up on bizzaro engine transplants into 240z's and the like I'd head over to the hybridz website.
D
Cheers Drew, yea my last c210 ran a L28, wild cam, some tuned length jap extractors and triple 45 webbers.It went very very hard. My mate has all of this now and has had it sitting for about 2 years,but will not part with it even when I waved $6000 under his nose.Never mind I'll see how the 260 goes and if not happy I'll look at something with efi. What type of V8 did Skylineman run?
Hi,
I checked the wreck at the workshop and couldn't find the the rubber strip you need (or any sign of the windows either!) Another friend who has a coupe must have poached it already! Sorry about that. I'd seriously take a chunk of the old strip into Clark Rubber and try to find a match.
Mr Skyline was running a 253 from memory. You can do a search and read some of his old posts relating to the car.
Also what kind of friend want sell you back your own car for $6G??? That's an amazing amount of money for a C210, the thing must be absolutely wild. Try and get a picture or two up for me if you can.
Cheers,
D
There's no car, wer'e talking just motor, webbers extractors. But to replace this taking into account the rebuild and this engine has the best of everything I'd be looking at $5000 or more, so Ireally beiieve the package was worth that sought of money. Triple 45's about $2000 or more new and the extractors are rare, what those are worth I've no idea.
I've been looking around for triples and your damn right they don't come cheap. So I guess a full rebuild with all the good bits can really add up. I really wanted a nice Kameari 3.2L Crankshaft for my L28, but they go for US$5,000 alone, so I see your point.
Hey Drew. been to see how my cars gettin on, basically it's not. They haven't started on it yet, promises promises.To top it off he's asking where the electric fuel pump and reg are? I informed him that I wanted to try without first, believing the machanical will suffice. He doesn't agree. In case he's right what elec pump are you running and how many gph does it pump. I was looking at a Facet 2-4.5 psi and it pumps 30 gph which the mechanic thinks is'nt enough. He's talking holley blue, 90 gph wtf. It aint a dragster.Your thoughts will be valued being as your running the same set up. Then I can tell him that I know someone....rah rah.... Do you ever have starvation probs when giving it some and some more? Ricky. I tried to put some pics up but again failed.
Hey mate,
Most of my mates are running Japanese Toiko pumps, and mines a Pierburg. Its nothing fancy and the car is not starving for fuel. I don't know the psi or gph unfortunately. If I can find the box it came in Ill let you know though.
D
Ok, found the box.
It's a universal inline Pierburg 12V, 3.9 - 5.5 PSI, model FPX030, and its about $150 from
http://www.injectacarb.com.au/fuel-pumps-c-33.html
There's a higher PSI model for the same price, but I don't see why you'd need it.
D
Ok, found the box.
D
Thanks D, Ive sent them an email asking what volume these pump. I spoke to a European car mechanic who deals mostly with jags and he reckons I'd be pushing it using more than 3.5 psi on my S.U's. So you see everyones got different opinions. I found a Facet 3.0 - 4.0 psi 120L per hour today at my local Repco for $100. If injectorcarb email me back with similar volume I'll purchase this pump.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
