I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕 hope it is not gearbox out. I will let you know.
If it's not the hydraulics, it is probably gearbox back out.
Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
@GTSBoy iam not a mechanic so what could typically gone wrong? It can help my mechanic...maybe he just forgot something or something like that that could help.
Yeah i thought. I took a LONG time to search for the right one.
Yes i read about all of that and i give him a call about that.
I look at those slave/master cylinders and they are not that expensive so i will be buying them anyway just to be sure.
@DuncanYou think it can be short? I double checked if that was a right one(it came with the clutch kit)
Ok i will give him a call. Hope it is some sort of "little error" and not some "yeah the gearbox needs to go out" one
