Intake Plenum Question - Dropping Boost - Also Good Tools To Have When Owning Skyline For $29 !
Made mine up using a piece of metal tubing the same size as my inlet pipe. Simply welded a cap on it and fitted a tubeless tyre valve.
We have pressure tested 4 lines with it to date, 2 with known boost leak probs which we found and fixed and 2 with the owners claiming no leaks. Both of these tests revealed multiple boost leaks.
Its a very worthy excercise imo.
Nice work fineline. Where were the main boost leaks? So you attached the inlet pipe you made to the trubo inlet hose? So you are effectively pressuring up through the compressor side of turbo?
Cheers
Edited by benl1981
So Adriano, do you think wack the old gasket back in with some goo? I can't see any holes in it. Anyone got any ideas from the photos?
Use HYLOMAR spray.... it is god on metal gaskets.
Well after adding gasket goo (to intake plenum gasket) and blocking BOV I am still getting huge boost loss after 5500-6000rpm. I am just dropping my cat to see if it looks collapsed. There is no evidence of leaking at the plenum gasket now so I think that's sealed.
I will make the pressure tester and check the inlet tract.
Only other thing I can think of is weak valve springs but you wouldnt think that would change in a week!?
I guess my centre muffler could have issues.
**PROBLEM SOLVED*** modified stock snorkel not allowing enough airflow or sticking to bonnet
Edited by benl1981
Hey fineline. What about the hose that takes the blow by from the rocker cover? That is connected to the rubber intake pipe. Should you block that so you dont pressurise the top half of the engine?
Cheers
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
