Hey guys having a problem with my car if anyone knows whats going on and can tell me your thoughts that would be great...
Ill start off by saying i just put in a boost gauge and boost controller (bleed valve) I put new heavy duty clamps on my intercooler yesturday so that I can boost my 32 without the intercooler pipe falling off all the time.. stock 7 psi i boosted it to 9psi when i got my new clutch fitted about a week ago but i wasnt thrashing it at all because the pipe fell off twice so i was taking it easy till i put in the new clamps.. so got the new clamps on so i increased the boost by 2 more PSI which shouldve made it 11 PSI but when i was running it, it was only showing 9 still.. so turned boost down to 7 and went up 4 PSI to make it 11 but now the boost gauge is showing 7 PSI... anyone know whats going on here?
Any help would be good...
thanks
https://www.sau.com.au/forums/topic/204150-boost-not-showing/
if it feels like its boosting right, i'd be looking at the boost controller accuracy, and the lines going to it.
if the car feels like its not making the higher boost, then check your boost controller. the turbotech type can get stuck. the spring gets caught on the threads inside, and the ball doesnt move freely. open it up and put it back together.
i just put it back to stock then i clicked it 4 times and it worked and it was fine then i clicked it 1 more because i wanted it at 12PSI and now its stalling everytime its not in gear so i put it down 1 like it was before but still stalling alot might be a boost leak...
nah the BOV is blocked..
i just clicked the boost back to stock 7 but its still showing it as running 9-10 wtf? dunno whats going on here.. car stalls so much everytime im slowing down to like take a corner or something i have to put the h/brake up if ive got someone in front of me and rev it a bit so it doesnt stall.. driving me nuts coz i cant drive properly!
Anyone have an idea?
Faulty boost gauge? Get a friend who has a working one and test it out.
The car is stalling? you must have over boosted it the first time and now you have a cooler pipe leak. Recheck all the clamps and hoses, and look where the boost controler is, kinda sounds to me like one of the houses must have a hole in there, happened to me a few times
get a friend to check it out and c what happens, then again you can always go to a mechanic
hmmm. i got a bosch 040 fuel pump in there with full tank of bp ultimate.. really hard to drive now.
when i floor it in first to 5000rpm i switch to 2nd and then floor it but it doesnt feel like its really pulling at all, feels like the boost goes away... the BOV is blocked by this tube thing my mate put on, i dont think its that though, because it was fine before i put in the boost controller and gauge, heavy duty clamps and boosted it. getting it checked from my mate tomorrow, also gotta put in a new clutch master cylinder.. hopefully it gets fixed tomorrow
It should be running 10psi stock as the R32 turbos have a 10psi actuator on them so they cannot run any less boost unless you have a huge leak or something similar.
Maybe your bleeder isn't set correctly and is leaking boost or even the BOV if its not blocked correctly it will leak boost pressure, as they are designed to do.
Hook up the wastegate lines as normal and make sure you have blocked the BOV off properly then try it again.
Where did you run the line for the boost gauge from?
Worse comes to worse I will have a look for you, your just down the road.
Let me know.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
