hey guys
my tacho seems to be dead...sumtimes it flickers, but most of the time it just drops down past 9000rpm (at the end of the gauge) and doesnt move, then sometimes it might start boucing around the 6 - 7k area wen ur really doing around 1500rpm....
what could it be?
has this happened to anyone before, whats the solution?
https://www.sau.com.au/forums/topic/204163-r33-s15-tacho-flickering/
Pointer detached from pointer shaft easyiest fixed, nackered tacho pickup maybe, bad earth maybe (but if nothing else is playing up this is unlikely), obscure electronic fault fixed by Nissan by replacing complete unit. :unhappy:
My 2c
Hope you get it sorted economically,
Cheers GW
where is the tacho pickup? could it be a loose connection or anything
yeh everything else works fine....
thanks
Loose connection is as you say also a possibility but if this is the case why don't all tacho pointers hang low when ignition off/no power? I would ask myself how can the pointer perform this trick & to me at least the answer is "it has somehow become mechanically disconnected from pointer spindle" to be able to float around &/or dangle at random in the manner you have described. I do not know where your tacho pickup might be placed, I have not had to dig into this to date, if I did need to I would be wading through the Japanese service manual floating around the forum environs (google) but I am sure others have this knowledge at their fingertips.
Time to visit a Skyline/Jap import friendly autospark in your neck of the woods I think.
Sorry can't be more helpful.
Good luck GW :)
Hope this is on topic but my speedo is out by aproximatly 1/2 so when i doing 30kmph it says i doing 15kmph. any suggestions?
Best option ; Re-scale dial 0 - 360kph? :)
Seriously, has this problem existed ever since your conversion to 25DET? Or has it popped up out of the blue? There are range jumpers on the cct board for the speedo/tacho array, discussed in depth on this forum in the "White dial 320kph group buy thread". Check it out & see what you come up with.
My 2c
GW :)
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
