Hey Guys, im having trouble locating a r33 s2 t superdragger exhaust system turbo back,
and was wondering if anyone could tell me anything and some brands about these " silent" high flow exhausts ? are they silent silent ? like a stock car or just quiet on low revs then scream like a normal high flow pipe when the throttle opens up ?
any information would be fantastic, as i am toying with the idea of getting a new exhaust soon.
Simon.
https://www.sau.com.au/forums/topic/204165-silent-exhausts/
My power II extreme Trust/Greddy with front pipe / split dump pipe from turbo back with high flow cat.. OMFG... IT SOUNDS MAD. I recommend you to get this! its not loud, only when you open it up its loud, even on high way driving.. its not even loud! Ask around for yourself! this catback system is 100% good. I searched on the fourms and fellow memebers told me to get it! so i got it! its so good... doesnt sound ricey, just pure sound!
Geraus.
https://www.sau.com.au/forums/topic/204165-silent-exhausts/#findComment-3619247
Simon.
im sure that any aftermarket exhaust which is larger in diameter would not be silent like stock. the hks silent pro would prob be one of the best ones coz u wouldnt have to sacrifice power loss with getting a huge center muffler. the silent pro will basically open up in high revs to give u maximum power whilst on low revs it will generally be quieter and also less dronier. i like mine loud. i have the trust titanium and had just got a resonator put in instead of the centre muffler. could definetely feel a difference power wise hehe...
https://www.sau.com.au/forums/topic/204165-silent-exhausts/#findComment-3619717
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
