Hi All, we are temporarily back in Sydney, managed to get the front on and measured the volume. It's about 32 litres. Not sure how long we're around for until we go back out so i'll just keep working on it until we go. Also front is not as big as I originally thought. 12 inch fit's niceley but 15 inch would be a little big. Only way I thought of putting a 15 in would be to extend the mdf front out further into the boot with a spacer. Then again the idea of this is to save boot space, so 12 inch it is for me. Is starting to look really good. will post some pics up if I get a chance to before I go. I bought some black gelcoat for the reproduction boxes so will look even better.
Cheers
Ben
  • Replies 122
Pics are up, still need to sand and polish the original so the mold will be nice and smooth. but this gives a good idea of what to expect. the reproductions will have a black gelcoat shell and will figure out the carpeting.
yeh mate, looks insane, being fibreglass...would these be good to be sprayed? or to have material on? i love the sprayed metallic look, but over-all it looks wicked...
how much would you be asking?
Yes mate..looks awesome...PAT ON THE BACK SON...JOB WELL DONE....
But I guess everybody else would be enquiring about the price for this...i'm sure you'll post it soon...
Oh and yeah...was that a 12" sub installed?
Hi All, yes as Adrian has said it is a 12" in the pics. Thanks mate. Still working on a price, won't decide until I see how long the reproductions take to make and carpeting costs etc. The box could be sprayed but as stated it will have a black gelcoat which should improve the look and I will investigate carpeting it when I get back.This may be the last post from me for a while. Catch up with you all when I get back.
i have done exactly the same thing not long a go and it works well, as i wanted a sound system with a 12' sub and amps in the boot but not loose my spare tyre. ill post up some picture tonight and show you want it looks like.
I've seen this done a few times but looks very neat.
If you do sell them I'll be interested in a couple months time when I get around to getting a sub :D
Hi All, managed to get the mold finished this morning. Once again back for a very limited time in Sydney. Just waiting on the ok from SAU to sell these using the forum and a small donation from each box sold will be given back to SAU. As soon as they give me the go ahead I will give a price. Just to give you an idea the price will be well under that of the commercially available equivalent.
Cheers
Ben
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
