Hi, Im upgrading my 94 R32 GTR only because i want more power, the engine is in excellent condition and i have some parts ill be swapping for higher performance.
-Fuel Pump
-Injectors
-Turbos
-Air Flow meters
-Cams
-GTR stock ECU Computer
These parts are from a stock 94 R32 GTR which has just reached 100,000km.
All still very good condition just wanted more power :rolleyes:
PLease give me some prices and ill get back to you if its a sell.
https://www.sau.com.au/forums/topic/204320-good-condition-gtr-parts/
All these prices are ONO
- Fuel Pump - $200
- Injectors x 6 - $300
- Cams - $300 for the pair
- Air Flow meters - $400 for the pair
- Turbos - $400 for the pair
- Stock ECU computer - $100
interested in the injectors, pm me or contact me on 0405073923 cheers also curious about the fuel pump.
Edited by allthewaytotheskyline
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
