hi i have a small issue with my r33 gtst. running 250bhp (186kw)
when driving along at ANY (even at 80 or 90mph) (128 or 144kph)speed and holding it at a set speed its like it drops in and out of overdrive but as soon as i come of the throtle and back on it or press the throtle it gose back to normal till it dose it again.
i have done a system check via the power button light and i got 1 long flash followed by 10 short flash so there seems no faulf on there and the atf level is ok and no burnt smell.
this is confusing me and i want to get it sorted as i have mv auto's valve body for it but dont want to put it in if the box is knackered
any help apreciated please
Edited by wolf
https://www.sau.com.au/forums/topic/204366-r33-auto-box-hunting/
Does the O/D OFF light on the dash also intermittenly flash on & off?
It's mostly likely to be electrical. Remove the shifter surround console & visually check the O/D button & along its wiring for any loose/ damaged connection. Then test it using a 12V test light or a multimeter on the O/D switch wire.
Otherwise you may have very low line pressure which can be casued by a number of things but, cleaning the ATF filter may help.
If neither of these are the case give Mike from MV Autos a call as he'll be more than happy to help you out.
Are you running an aftermarket computer? If you are, almost no models come with a shift controller for an Auto box, as a result, the ride will be ragged an unpredictable. They basically run maximum line pressure, rev it up and just whack her in gear whole doing funny things with your O/D. Best thing if you're running an aftermarket computer is to purchase a separate shift controller unit and install that on the car so it has the smarts to deal with the auto box.
nope i have the standard ecu and no other add on computers
i did do an ecu reset and was fine for a few days then came back
  • 3 weeks later...
i have a similar prob. it also happens when cruising at anywhere above 80kph. the box just drops into overdrive and refuses to shift up. sometimes it seems to do it less if im in snow - which also seems to make it shift up sooner. i have tried completely coming off the throttle but it does nothing positive. i have to rev it hard in 3rd to maintain speed. once i clunked it into neutral and back to drive. seemed to do the trick but only that once.
yep but what i have found is when i do an ecu reset it goes for a few days. also when it does do it i now give the accelerator a bit of stick and it goes and stops doing it till next time the car is switched off. but got mv auto's valve body a new filter and oil for it so see if that cures it
  • 1 year later...
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
