hi i have a small issue with my r33 gtst. running 250bhp (186kw)
when driving along at ANY (even at 80 or 90mph) (128 or 144kph)speed and holding it at a set speed its like it drops in and out of overdrive but as soon as i come of the throtle and back on it or press the throtle it gose back to normal till it dose it again.
i have done a system check via the power button light and i got 1 long flash followed by 10 short flash so there seems no faulf on there and the atf level is ok and no burnt smell.
this is confusing me and i want to get it sorted as i have mv auto's valve body for it but dont want to put it in if the box is knackered
any help apreciated please
Edited by wolf
https://www.sau.com.au/forums/topic/204366-r33-auto-box-hunting/
Does the O/D OFF light on the dash also intermittenly flash on & off?
It's mostly likely to be electrical. Remove the shifter surround console & visually check the O/D button & along its wiring for any loose/ damaged connection. Then test it using a 12V test light or a multimeter on the O/D switch wire.
Otherwise you may have very low line pressure which can be casued by a number of things but, cleaning the ATF filter may help.
If neither of these are the case give Mike from MV Autos a call as he'll be more than happy to help you out.
Are you running an aftermarket computer? If you are, almost no models come with a shift controller for an Auto box, as a result, the ride will be ragged an unpredictable. They basically run maximum line pressure, rev it up and just whack her in gear whole doing funny things with your O/D. Best thing if you're running an aftermarket computer is to purchase a separate shift controller unit and install that on the car so it has the smarts to deal with the auto box.
nope i have the standard ecu and no other add on computers
i did do an ecu reset and was fine for a few days then came back
  • 3 weeks later...
i have a similar prob. it also happens when cruising at anywhere above 80kph. the box just drops into overdrive and refuses to shift up. sometimes it seems to do it less if im in snow - which also seems to make it shift up sooner. i have tried completely coming off the throttle but it does nothing positive. i have to rev it hard in 3rd to maintain speed. once i clunked it into neutral and back to drive. seemed to do the trick but only that once.
yep but what i have found is when i do an ecu reset it goes for a few days. also when it does do it i now give the accelerator a bit of stick and it goes and stops doing it till next time the car is switched off. but got mv auto's valve body a new filter and oil for it so see if that cures it
  • 1 year later...
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
