Hi all,
Nissan Skyline R34 4 Door
62,700 Km's on the clock
Transmission:5spd Man
Colour: Black
Complied? Yes - Im the first owner in Australia
RWC supplied? No
Currently registered? Yes
$18,990
Modifications:
Engine is stock, only has pod filter.
Suspension: TIEN Coil Overs all round, Height and Damper adjustable.
Will come with standard Nissan OEM Wheels
3" Exhasut CAT back - Blitz NUR spec - (with silencer), really nice note.
Xenon Head Lights
Small Skirts/Body kit.
Factory cd/tape deck
Cadence 2way 6" speakers in rear, factory front speakers.
Standard Boost - never been boosted - engine all factory
car serviced spoton every 5,000k's, approx 700k's since last service - fresh oil and oil filter (always used Castrol Racing R oil)
recently put in new NGK spark plugs also.
Code Alarm Keyless entry and Immobilizer Installed by Zylux.
contact Ben on: 0418 556 519
email: [email protected]
Edited by FULOCK
https://www.sau.com.au/forums/topic/204615-r34-4door5spblack-18990/
Nice car mate just out of intrest I now have 2 kids, a three week old and a two and a half year old and we can still put a small adult in the back seat and put a velco run about delux 3 wheeler, porta cot and luggage in the boot with just taking one wheel of the side of the pram. With a bit of careful packing they still work quite well and they will use allot less fuel and be much more fun to drive around than the stag. Buy the way what type of kit is that.
Thanks Mate,
Yeah I know with a bit of tender loving care I can make things fit coz they do have a reasonable boot.....
But I just want the convenience of a Wagon but still love the performance and note of the NEO engine....
With the wagon I wont have to be so carefull with stuff in the boot!! :stupid:
I've been told its a Nismo kit - but honestly dont know....?? anyone else recognise it or know what it is??
Guys/Girls,
I need this car gone ASAP!!!!!!!!!
Reasonable offers will be considered - just get in touch with me and we can talk!!
I check my PM's daily!!
Last six months car has only been driven once on the weekend if lucky!!!
always kept clean and VERY well looked after!!!
Good luck with the sale, your 34 looks very neat.
I am in the same boat, 3 little ones (3mths, 2 & 4 yrs) in the back now makes it nice and cosy, but a bit restrictive with prams and bikes and shopping in the boot.
I cannot believe this car is still up for sale!!!!!!
if anyone is worried about it being a 4 door..... seriously it looks crazy in real life.... i think much better than the coupes!!!
when i bought it i came across it by luck.... i then completely forgot about all the other coupe's i looked and and took this straight away!!!!
some moron reversed into the rear right corner at work months ago which is why the rear bar needs a re-spray - only a hand-full of paint came off, no structural damage at all!!!
I looked after this car better than i looked after myself!!!!
price is down again to $$18,990
Please contact Ben on the below details as I don't own this car anymore - to have a look at it I believe it is in Brighton, but have a chat to Ben and he'll let you know
Ben - 0418556519
[email protected]
Edited by FULOCK
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
