  • Replies 487
Posted Images
It's alright, it's sorted out now :D
HI Steven,
Just letting you know that the money was deposited thanks.
Can you also pass on my regards to Duncan for getting this done!
I will honour the buddy pass for this show for your members.
Okey dokey...
If anyone knows where we can get a decent flooring material that cars can go onto, let me know ASAP! Our idea is kaput right now, and the only other option is to rent carpet tiles (1x1m a few dollars each, we have 120 square metres).
So yeah. anyone? :happy:
Paul is racking his brain thinking up some other ideas, a few weren't bad... But if anyone else can think of something, or knows someone that might be able to get us a whole shit load of something flat and long, let me know :D
And yeah, I haven't washed my car in ages... hell, I've barely driven it :)
Polished timber floors ?
Or a Pit Lane set up ?
With chicks :happy:, in not skimpy, but good looking Pit lane outfits, not modelling, just wiping down the cars and shit.
Hehe, back on topic.
Or jungle effect lol, Nissan Skyline " KING OF THE JUNGLE "
MRXTCZ
All entrants can you please remember to bring down a fold-out chair for yourself. I'm bringing down 2 maybe 3 but just so we aren't short-chaired can you please BYO chair.
...an esky wouldn't go astray either.
Lol, aiight im gonna want to see this, this weekend is gonna be crazy.
Do you guys know where your gonna be placed in the building ?
I'll probably bring my skyline down aswell. I'll come look for you guys on saturday..
MRXTCZ
Looking forward to it now guys.
I just received the message from Auto Salon saying that we need to go in at 3pm. Can you guys 100% with me its ok I can bring the car down later?? As I work close by'ish, Fox Studios I can pretty much guarantee being there before 5:30pm. If not, I'm going to have to try and get the avo off or something..
Please let me know :D
Tropical Box:
tropical_fish_toy_box.jpg:P
In all seriousness, I think they're esky's, just good ones!
har har :(
Yes you can bring the car in whenever you want... we probably won't be set up til then...
At last years first show, the guys from (insert some name I've forgotten here) decided to make an entrance and rock up at 9:30... cars like BLODIS with an engine that blocks the windshield idled past everyone humming at about 120db or so... They were in the far corner behind us :D
But yeah, if we're in a half decent place, you can come in whenever you want... I'm sure Paul cam let you know on the day :devil:
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
