Guys I have done some searching but everything I find is old as the hills...
Im really keen for a power fc, but where on earth can I get one?
Also does anyone know of anywhere who might have a second hand one? Or is that just a bad idea all together??
Thanks every1!
Cheers
https://www.sau.com.au/forums/topic/205141-power-fc/
you can get them new again. just trying to rack my brain where from. they are about $1540 with hand controller, and they were in stock, but just gotta remember which online trader had it. will edit my post as soon as i remember
https://www.sau.com.au/forums/topic/205141-power-fc/#findComment-3641805
