Item: HKS GT-RS turbos
Age: used, 7000km
Condition: excellent condition, no shaft play.
Price: SOLD Pending Payment
To Fit: (What car) RB26 direct bolt on turbos
Contact: PM or email to [email protected]
Comments: 2 Turbos only. largest low mount twins for the RB engines.
Item: Fujitsubo Super Ti 80mm exhaust SOLD
Age: used, 1 year
Condition: excellent, slight dint near rear diff, does not affect performance
Price: $SOLD
To Fit: (What car) R34 GTR, R32 GTR
Comments: Excellent Titanium exhaust, easy can handle 300KW ATW. Weighs 6.4kg
Movie and sound file can be access here:
http://www.fujitsubo.co.jp/product01.php?n...000000000003147
Item: ARC Blow Off Valves
Age: used, 1 year
Condition: Good up to 1.4 bar
Price: $300
To Fit: (What car) R34 GTR, R33 GTR, R32 GTR
Comments: Good upto 1.4 bar
Item: Nissan N1 oil pump SOLD
Age: Brand New
Condition: Brand new
Price: SOLD
To Fit: (What car) RB26 engines
Comments: brand new N1 oil pump off N1 engine.
Item: Nissan N1 camshafts / cam gears
Age: Brand New
Price: $500
To Fit: (What car) RB 26 engines, Rb25 engines
Comments: Brand new N1 camshafts off N1 engine.
Item: NISMO Weldina metal cat converter
Age: 1 year
Condition: excellent 80mm (3") cat
Price: $500
To Fit: (What car) R32, R33, R34
Comments: Nismo Weldina metal CAT suit 80mm 3" exhaust system
Item: Nismo steering wheel boss kit with Nismo horn button
Age: Brand New
Price: SOLD
To Fit: (What car) all skylines
Comments: Brand steering wheel boss kit
Edited by baboo
Age: Brand New
Price: $350
will this fit a R33 GTR? If so I'll take it pickup :/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
