  • Replies 200
Posted Images
am dropping my car to him and bringing his car if he is not using his car...photos only alowed if you bring chic for me too this time james :-)
Got a girlfriend now cuz.. So that phase is all finished... =) Look at it like this, if you know how to go fishing, then you'll know how to pick up girls.. The ethics are the same. You need time, patience, and to be looking in the right spot. And at the end, you get rewarded with a great catch! LOL
Awesome 350 :)
Yeah James is kunnected with IgnitionDVD, he should organise some models to pose with our cars :)
LOL Omar... I've been trying to call Matt from IgnitionDVD, but am not getting through. I'll give you updates as soon as I get through... =)
Just spoke to Matt from IgnitionDVD. Most likely they'll be coming along for the drive taking video footage!
Best behaviour everyone, and make sure those cars are shining new!
is that the same one who u brought for cruise to gong from natio park?? Good on you bro i am single now so i got the fishing rod ready hehe
No, that girl was just a friend. This girl, I'm actually going out with... =)
I spoke to Matt about the footage from the last Palm Beach Cruise, they haven't used them as yet on any dvds. But as soon as they do, he said he'll pass some copies to me.
At this stage my car is MIA. I'll be getting the fuel pump fuse-blowing incident sorted this week so i'll still make the cruise if all pans out at the workshop.
Got the car sorted yesterday, so i'm on for Sunday. I'd like to thank Yavuz from UniGroup, and all the fans who supprted me during this difficult time :thumbsup:
Never been much of a fishing man. I prefer hunting. If they don't come quietly just use force :)
:P
Got the car sorted yesterday, so i'm on for Sunday. I'd like to thank Yavuz from UniGroup, and all the fans who supprted me during this difficult time :banana:
Never been much of a fishing man. I prefer hunting. If they don't come quietly just use force :P
I get my car back tomorrow Omar, so I'm cheering! Nearly two months off the road! DamN!
I think I'm out for this one sorry guys, car is overheating pretty bad ie 20 minute drive and steam coming from around both headlights, pretty sure it's the coolant in the radiator, unfotunately the coolant flush is booked for Monday morning :( and I'm no good at doing these things myself pluse I have no chassis stands.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
