I have the following aviable
1 x R31 Turbo (with lines & bolts) 24,000km's
1 x R32 ECCS Plenium
1 x R33 Standard Exhaust manifold
1 x R33 O2 sensor 7,000km's
1 x R33 Dump pipe (half a foot long u know the one)
and theres a heap of other crap in the box i dont want
like heat shields and mounting brackets for the bits and
pieces im selling.
Want to sell to Brisbane person as mail would be expensive
for a box so large and very heavy.
Need $200 firm for the whole box...
https://www.sau.com.au/forums/topic/20550-r313233-bits/
The R31 turbo bolts onto the r33 exhaust manifold all of the exhaust manifolds are the same R31,32,33.....
Im selling the turbo separate for $150 now....
150 is last offer and is firm sale.....
The rest of the junk make an offer
Note: the turbo comes with the oil & water lines
Call me on 0433 123 024
https://www.sau.com.au/forums/topic/20550-r313233-bits/#findComment-441491
  • 3 weeks later...
  • 4 weeks later...
hey, how much r lookin for in rgrds to the std maniflold and R31 turbo?
how many k's on the r31 turbo? bolt straight on to the manifold?
what is the difference btwn that and a r33 one? power wise? design wise?
thanks
https://www.sau.com.au/forums/topic/20550-r313233-bits/#findComment-522425
... ok for the last time...
I dont check this forum....
Phone me on 0433 123 024
No plenium pipe over cam cover
02 sensor is worth more than 10 bucks
r31 turbo is not a good choice for an r33....
(thats why i pulled it off and put an r33 one on)
please ph me....
https://www.sau.com.au/forums/topic/20550-r313233-bits/#findComment-525094
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
