take it out, scrub it with metho to remove the dodge factory paint. Respray with plastic primer and Powerplus Desert Rose Metallic to get a close to factory look (don't forget to do the triple gauges and A/C cover so it looks the goods)
Link http://www.skylinesaustralia.com/forums/Sh...l&hl=666dan
  • 2 months later...
how do u remove the whole panel..what screws do i need to unscrew? im having a hard time and also the AC? its for an R34 Auto btw. and what sanpaper grit did u use ??
I just did mine today!
Many thanks to 666DAN's thread for giving me the inspiration.
I used the powerplus desert rose like Dan did, and also their silver for the gear and stereo surround to give it that brushed aluminium look that's like in my Z :cheers: .
R32___Australian_Specification.pdf
Edited by Yo-Yo
1. Start off by taking out the ash tray, you'll see a screw holding down the gear stick surround, once it's off you can pop out the surround (dunno if there's anything extra involved for an auto. You'll need to unplug the alligator clips holding the cigarette lighter
2. Use a flat head screwdriver and wedge it in between the air con vents and the edge of the dashboard being very careful not to scratch anything, easiest to do it on the opoosite side of the hazard lights, gently pry the air con vents out until it comes loose, you need to unclip the hazard lights. Up to you if you want to take out the hazard switch for painting purposes, simply hold the clips together holding it in and slide the switch out.
3. The first 2 steps will reveal the screws holding in the air con unit and stereo, unscrew these and the aircon and stereo come out together on the same bracket. You can then unscrew the air con unit and take it out. Once that is done you can then unscrew the stereo surround and take it out.
4. now that these are out the last thing left will be the triple guage pods up top. When you take out the air con vents it will reveal the screws holding the pod in place. once the screws are off it's a simple case of sliding it forward and out to reveal the screws holding the guages in. The guages are a 1 piece setup so all you need to do is unscrew them at either end to remove.
5. Paint the parts to your heart's content then put them back into place in reverse order
Thanks for the instructions!!!
Btw ur dash looks great :laugh:
Im going to do from the triple guage holder down to the gear surround in silver. Will 2 cans do it?
Just rang Supercheap auto, they have the small powerplus pressure packs for $10.99, and the plasic primer is $17.99. i think ill need about 3 paint cans and one primer?
Edited by Damo_R34
Btw ur dash looks great :dry:
No dramas at all buddy
:merli:
1 primer should do it.
I only did the gear surround, ash tray, stereo surround and the side panels for the power windows and I only JUST got enough paint out of 1 can to do them all with the small pressure packs, so safe to say 2 would be needed.
I did the aircon unit, air con vents and guage pod in the darker paint and that used up about 3/4 of the can doing 4 coats of paint on all those panels.
Thanks heasp for the info. should have pics up on sunday when its done!!!
I used the powerplus desert rose like Dan did, and also their silver for the gear and stereo surround to give it that brushed aluminium look that's like in my Z :banana: .
dude, how did you get off the parts around the power window controls? they look good
The power windows and mirror switches can be taken out pretty easily, unclip them from the power wires first obviously,
the power windows switch has 3 screws that hold it in.
The power mirror switch has two sections you can squeeze together to make it pop out, you'll see what I mean when you do it
Edited by Yo-Yo
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
