Hey guys, its time i servcied my R33 Gts-t and i was wondering if any of u guys reccomend a really good OIL and Coolant for my car? i donno whats in there Now, and there are so many diff brands on the market! what is the most commonly used and most effective for Gtst's? / or jap imports.
https://www.sau.com.au/forums/topic/20553-what-oil-and-coolant/
The factory spec is 7.5W/30, but I've used both 10W-60 and 5W-30 synthetic with no problems at all. The 10W-60 is too thick though, and robs power from your engine with no real extra protection benefits. I would use the 10W-60 if the rings were a bit worn, but if not, then something thinner.
Keep in mind that any oil designed for high revving 4cyl engines is also good for Skylines, even though it's 6cyl. The reason being it's a small 6cyl engine and revs quite high. The pistons in an RB25 are actually smaller than those in an SR20.
A lot of people use 0W-40 with excellent results. Just whatever you get, stick to something semi or fully synthetic and you should be right.
As for coolant, just a good brand that's designed for alloy engines. I've got some Nulon concentrated stuff ready to go in. Mix it with distilled water if it's not a pre-mix to make sure you don't get weird metals in your engine.
For more detailed answers, take Ronin's advice and search :P
i use penrite 15w60
i like the fact that it goes up to 60, as it revvvs lots and i like the fact that i am protected even at 7000rpm!
and for coolants, make sure u use anti-freeze/anti-boil not just the normal stuff. this prevents corrosion as well as working well. 50:50 ratio works wonders...
Guest RedLineGTR
Been using 5-40 Motul 8100 seems okay...was using Shell Helix Ultra 5-40w with useing the shell oil...the engine ran cooler the engine temp was lower and because of that the coolant temperature goes lower than it ever did with motul..after this i think i'll stick with shell...unless i wanna spend $100 for redline oils.
I like Formula R too. Currently using 5W-30 but used 10W-60 before that with no ill effects other than losing some power. It's not the best synthetic oil out there but still excellent IMO. If you change your oil often (5000km or so) then you can get by with the cheaper stuff. It's only $50 for 5 litres anyway (5W-30).
Gunner, the numbers are the viscosity numbers. The first one is the cold (starting) temperature viscosity, and the second number is the hot (operating) temperature viscosity. I'm not sure at what exact temperatures the numbers are rated at or what they directly translate to, but generally speaking a "10" is fairly thin, and thin oil (cold weight) is required on modern cars, especially with turbos.
It can go down to 0, which is ultra-thin. This seems to be ok with Skylines with engines in good condition. I wouldn't want to go any thicker than 15 or so for the cold viscosity in a Skyline.
The second number is less important. It can be thick or thin (to an extent) but most Skylines are happy in the 30-40 range. Any thicker than this and you tend to lose power.
Thicker grades are generally only for engines with worn rings. The thicker oil doesn't get past the rings as easily and you burn less oil. If your engine is in good nic you should be able to get by with a fairly thin (30-40) oil.
Thicker oil is also required in extremely powerful engines. I don't know where to draw the line, but it's not at my car's power output (approximately 200rwkw).
RedLineGTR, the 5W-30 isn't too thin at all. It's designed for high revving 4 cylinder cars, including the SR20 engine, which has larger pistons than the Skyline's. So you could even say that the RB series of engines are more of a 4 cylinder engine than an SR20 :D The factory spec for Skyline oil is 7.5W-30. There are plenty of people running 0W-40 with no problems so obviously you can go lower than this (cold weight) without any problems.
Edit: If you are burning oil in your engine, or you have buckets of it in your catch can, you probably need thicker oil (50-60 or so). If the engine is tight as a drum, the thinner stuff (30-40) is fine. Even with 5W-30 oil in my engine there wasn't a drop coming out of my crankcase breather for over 2000km.
thanks for the help.
Im currently using turbolight oil.. seems to be great. i get good power from the car 140rwk's ( sr20 ) i think i one in there is about 10 - 40. seems to be fine, thank's for the info.
so i could put something a little thinner in there and the engine would be just as happy. ??
Gunner, if you are not burning any oil and don't have much blow-by from the crankcase (check the inside of your intake, or oil catch can if you have one) then the thinner oil will be just as good. Better even, because there will be less drag on your engine internals and you should get slightly better power and economy (that is the main point of using the thinnest oil that your engine will tolerate).
Do a compression test on your cylinders if you want to be doubly sure. If it's all good then 5W-30 will be fine.
people keep saying that you lose power if u use an oil with a high temp viscosity greater than 40.
what i want to know is: has anyone actually moved to a thicker oil then thought holy sh1t i can actually feel a power loss. Or, is this just something someone said and everyone agreed with because they want to look like the know stuff (happens a lot from what ive seen)?
WazR32GTSt, I can say the opposite. I was using 10W-60 oil then switched to 5W-30, and the engine felt more free-revving at the top. Not by a huge amount, but noticable. My fuel economy also improved by around 0.3 to 0.5L/100km.
There is no doubt that thinner oil will give you better economy and power. It's just physics! Everything that adds drag to your engine will reduce its power. Thicker oil creates more drag than thin oil. You can't go too thin though or else it would all drain down the gaps in your rings and not lubricate properly and/or burn excessively. That's why as your engine wears, you need to use thicker oil.
There is generally no harm in using oil that's too thick. Aside from the cold weight - if it's too thick it won't reach the upper parts of your engine and turbo quick enough and create excessive wear on cold starts. But if you use oil that's too thick for the condition of your engine you will be sacrificing power without any extra engine protection (see my exception above about uber-powerful engines).
Thinner oil is free power. Thick oil doesn't provide better protection unless your rings are worn.
thanks mate
i know by the physics of it that thinner oil should be better for power but i was looking to see if it was a difference that was actually noticable or not.
has anyone else had this experience?
btw, dineth: i hope this isn't hijacking your thread as i thought it was relevant to the topic. if it is i will start a new thread...
mate I used MOBIL S semi sinthetic 10W 40
quite good result. Motul 10W40 full synth is good
value. the only thing you'll get out of 0W or 5W oils
is some fuel consumption.
bear in mind factory standard when all is new is 7,5W
so as your car ages you should go a little thicker,
but all dependant on your engine age, kms etc etc
10-15W seems a good choice ...
Hope it helps
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
