Heya Guys!
Well for my bday I got a 40cm wide and 60cm high hexagon aquarium, i was wondering if anybody here would be able to make me a stand and hood at a reasonable price? wood or plastic ... i have been quoted some ridiculous prices and have had enough so i thought i would write on here to see if anybody could help me get a good price..... please
Thanks guys!!
Dan
https://www.sau.com.au/forums/topic/20561-cabinet-maker-or-carpenter-needed/
Dan, Have you thought about trying it yourself. It wouldnt be that hard at all (heck at school i used to make all sorts of boats, clocks, a big table and cabinet things in woodwork). I'm the sort of person who would rather pay someone, but it can be worth it to give it a go yourself!! :D
Getting GOOD QUALITY wood (stick to wood, rather than plastic) is easy enough (and fairly cheap) and unless you wanted fancy designs, you could make the stand any shape, size or design you wanted. Will work out a lot cheaper and it wouldnt take that long.
A mate has a similiar tank, so if i get a chance i'll go up tomorrow arvo and get some pics. Very simple design but looks fantastic.
What sort of fish you plan to get??
Guys - unfortunately wood seems to burn every time I try to weld it at garage malaga... ;)
won't be able to led a hand on this one...
Dan - as Docile said, get some mdf and make it up to suit - easy as.. paint it for that nu-vogue pimpy look.. :)
OK Adrian and Cam so is that idea out? if so Perhaps after speaking to Mat (Docile) i will try and make one myself with Mat, reminds me of a simpsons episode where homer tries to make a spice holder.. why do i get the feeling that my backyard jobbie isn't going to go to plan..... with me they never do.... ask paul!!! :-)
Originally posted by zanda
better still, cover it in checkerplate, and stick some neons in it!
the fish will think it's a disco, and all wig out!! Ha-ha!
:uh-huh:
AHAHAHAHA!!! check out those fish...
yeah checkerplate and neons should to the trick and whack a 5 speed turbo charged filter on it!! yeah FULLY SICK!!
Dan, Like i said, it wont be perfect but as long as we sit down and have a bit of a think and take our time, we should do a pretty good job!! Next time i see you, i'll show you the clock and stuff i made for a bit of confidence boosting!
We should be able to add a couple of shelves and stuff for the filter and air pumps etc
Cheers
Mat
Originally posted by GTAAH
Yeah I know that's what the bonnet is for, but even Dan isnt a big enough tosser to install a fish tank in his car. I hope.
Jash
No, NO FIsh in the car.... got some probs with the turbo as it is... a fish tank is the last thing on my mind at the moment! then again some goldfish would look cool in our tail lights! ahaha!
:( :bahaha:
Grey skys: well if its ok with you, do you want to spend a sunny arvo with myself and docile sinking down beers (i will supply!) and making up a nice aquarium stand! hmmm maybe we should stay away from the beers until we have finished?? eheheh! :uh-huh:
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
