Can someone explain why Chrono 300v is better for my stock turbo R33 streeter daily?
I use 4100 and i thought it was good (guess i was WRONG then). Why is Chrono the sh*t apart from being fully synthetic (i get that part), any other reasons? Or it just has a better name?
the fact that it is FULLY synthetic "IS" the reason.
Your car will run on 4100 or any other kind of oil.
people treat their cars well.
if you were hungry, and felt like an apple, would you get one that's been left in the sun for a few days and a little bruised? or pay double the cost and get a perfectly green, perfectly round, bruise free, crisp, cool granny smith.
both will reult in no more hunger, but one will definitely be better for you and make you feel better.
/food comparison.
other than that, the people recommending the best are the same people who have spend many thousands on their motors and don't want to have to do that again, so they do "ANYTHING" they can to prevent that situation.
$100 for oil is cheap for them compared to what they spent to get their engines brand new, and they will do whatever they can to keep it that way.
the fact is that Taxis do million km's using just your regular shit $30 oil.
if your car is a street only car that makes under 200rwkw, and driven sedately most of the time, you can use the $40 4100 turbolight oil.
just check it and change it before the 5000kms.
from what I can remember when I was using it, that oil went black, realy quick.
I spent the extra $30 and got Castrol Edge 10w-60 - 5L for $70
  • 1 month later...
hi all,
i need some good oil but can't find a local stockist
dose anyone know where i can buy Motul turbolite 4100 10w 40
off the shelf.
i know it can be ordered but i don't have the time to wait for it
The closest so far has been dural *ftw
any help would be great
Mate you should be able to get Motul Turbolite from any Repco or Autobarn store!
300V Chrono is specifically designed for race purposes. It does have excellent street applications but you probably don't need it unless your heading to the track on a regular basis. Check out linkauto.com.au and go to motul and then click products. If your looking for a step up above 4100 then 8100 Xcess has some of the tech of 300V and is a good compromise (incl price).
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
