Ok i'm Importing a GTT 34 Sedan soon (well Ferah is for me) and i would like some ideas on Kits and rims!!!
I think i know what i want but some new ideas and pics would be good! Ferah what was the name of the Kit we were talking about?
I'm going to bring across a Clean Stock 34 and do the mods when i get it here!
so if you can post up some ideas and some pics that would be great (so i can atleast start looking for a kit as well)
I like the CWest and Bomex but more ideas would be great!!
cheers
https://www.sau.com.au/forums/topic/205699-34-body-kit-suggestions-please/
  • Replies 43
Posted Images
Hey Kira
for 34 sedans i like the URAS kit like what they run in the d1 car
looks tuff with some nice dished wheels :(
although the monkey magic kits are really nice to :P
have a look at the link they got 3 kits avaliable :)
http://images.google.com.au/imgres?imgurl=...l%3Den%26sa%3DN
Thanks Boys can you please have your cat fight some where else this post is about me KTHXBYE LOL
GTR Front mmmmm naaa i dont wanna copy Ferah lol i want her car to be unique, and same with mine!!!! Plus i'm not one for Mock ups!! i like to look of them, but its just not something i like to do!
Hey Kira
looks tuff with some nice dished wheels :thumbsup:
although the monkey magic kits are really nice to :)
have a look at the link they got 3 kits avaliable ;)
OMG NICK that place is soooo F**KN expensive!! by the time i buy these kits and have them fitted i may as well import one done up!!! GEEESSSS!!!
any other places that stock these kits?????
what ever you dont get a Plow King body kit. some simple side skirts and a front bar is all you really need. and a nice set of wheels. most cases a little is better than over the top.
lol i just googled the r34 sedan d1 uras kit :banana:
check out these ones there in aus but they wont have the best selection if you get a car thats got standard kit
these are the same company
http://www.skylinesaustralia.com/forums/Ni...it-t187734.html
http://vivagarage.com.au/Products%20Page/N...ts_1_popup.html
http://www.carmate.com.au
http://www.justjap.com/parts_nstyling.htm
http://www.nismo.com.au
thats all i could find atm
like i said to you
its hard to fit kits for 4 doors ;)
unless you wana spend the money and get it from japan most people dont have many kits he in aus :D
Kira it was The URAS kit :banana:
i dont know if this company is good but go to carmate.com they have a list of fronts and side skirts and stuff like that and there is some good ones at good prices too.
I dont think Kira will make the same mistake twice, the last kit she got off them she wasnt 100% happy with!
think the best kit you can get for the r34 sedans is the factory nismo ones
:):D I hate the side skirts and rear bar of that kit!! Love the front bar tho!
the sedans dont use the same nismo skirts/rear bar as the coupes.
this is the 1 i'm talking about (missing nismo front bar)....
its ok but a bit boring for me! looks stock!! but thanks anyway!!!
There is only one kit for a R34
http://sunline-racing.com/gtr34/
Lucky for the average joe GT Autosound in SA have the moulds.
I like that but thats a GTR?? i dont want mine to look like a gtr!!!
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
